Question about InFocus IN35W Projector
Infocus IN35 projector has vertial lines covering the images
I'm trying to show a powerpoint presentation on my laptop, but it's covered with horizental lines resulting from the projector. I'm not sure if this is an issue with the lamp or the laptop. The projector is relatively new so I'm not sure why this is happening. I hooked up two seperate laptops, byut the same thing happens. Any ideas?
  • mbaton May 12, 2009
    They are black lines and they are spaced evenly. images will, however, appear through the lines.
  • 3,037 Answers
Usually this is a problem with the lamp. Sometimes you get a faulty lamp. Otherwise the board is bad if the lamp isn't or you may even have a bad cable between the computer and the projector. I would first try a new cable, then a new lamp. Are the lines any certain color and are they spaced evenly? Let me know if you have any further questions.
Benjamin
Posted on May 12, 2009
  • Benjamin Patri
    Benjamin Patri May 12, 2009
    Ok, yeah most likely the cable or the lamp then. If under warranty, get it replaced for free or return and get a different one. let me know how it goes
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Infocus IN35 Power Problem
check the interlock switch for the lamp door (on the fan bracket). if the switch doesn't work, the projector won't turn on. also check to see if the ribbon cable for the top case buttons is connected well. if still a no-go, it is the power supply (part # 510-2189-00). if you want to try and fix it instead of purchase it, start with the caps. some of them bulge and some tend to dry out prematurely without physical damage showing. start with the large one in the middle. you should at least get 5v from one of the points. you won't get any more unless you get a signal from the main board turning the rest of the power supply on. and there's where the problem may lie.
Sep 07, 2009 | InFocus IN35W Projector
Problem running power point with embedded video file on projector
I too got the same problem once.But some how i had managed to solve it.Actually it is due to the corrupted header of the ppt file i.e the system can read ppt location of the memory but unable to reach the video file .The solution is you just need a powerpoint 2007 file recovery tool.The tool i used is provided here.Why i am recommending the tool is it makes a copy of the ppt and then repairs it .so there wont be any further damage.The demo version is here.If satisfied with demo reach the full version of it as i did ...
Feb 26, 2009 | InFocus ScreenPlay 4800 Multimedia...
Infocus x1 image issue
the light tunnel has collapsed and needs replacement. it's only about $10 and fairly easy to replace.
Sep 29, 2007 | InFocus X1 Multimedia Projector
Screen goes blank momentarily
cover up the infrared remote sensor on the projector. The heat of these colours or something might be messinf with the infrared remote sensor. TRy this and see what happens. It may just be bad contacts. Some projectors just cant handle stuff like this. Some were meant for presentations and presentations only. BUt seriously try covering the remote sensor to see what happens. If it is an older projector the infrared signal detector might be sensitive to bright light or stuff like that.
Aug 23, 2007 | InFocus ScreenPlay 4805 Multimedia...
InFocus IN35W Projector Logo
159 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
