Question about Canon XEED SX50 Multimedia Projector
Canon XEED SX50 Multimedia Projector.Power is not getting ON
Hi, I have a Canon XEED SX50 Multimedia Projector.Power is not getting ON,powercord OK,lamp no signs of burnt off, what could be the problem ? Where can i get it serviced in AP, south India ?
I had the same problem.
maybe your xeed got overheated and the security fuse blew off.
its easy to turn it back on.
open the housing by unscrewing both side panels
open the top panel screws (they are belo both side panels)
carefully remove the top by tilting the front and bending it to the backside.
now open the 2 screws of the metal shield right above the lamp housing.
below you have two brown cables ending in the heat fuse.
push the switch of the fuse until you hear a click noise...
power should be back up again - BUT the fuse blew for a reason so check all fans and the location where you use your projector for proper cooling!
if this doesn't help and you have some problems with your local power supplier change the power fuse which is right on top of the power cable but the metal plate has to be removed first.
its tough because you have to loosen about a dozen screws...
hope this helps
have fun
daniel
Posted on Jun 20, 2009
I have nec projector. power is ok but doesn't on the projector
Hi
if power on button press & indicator becomes green , but lamp do not get on ,check the lamp
Mar 04, 2016 | NEC NP115 DLP Projector
Image/power issues
A lot of projector lamps / bulbs only have 2000hrs of expected life. that's about a year if you use it to watch TV. Do you have a backup to try out ?
Oct 25, 2013 | Canon XEED SX50 Multimedia Projector
My canon xeed x600 show warning lights when i turn on
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Sep 07, 2012 | Canon Lamp for XEED X600 Projector
The 4100mp dell projector will kick off about 5 minutes after bing turned on. I read somthing about a filter possiblly being cleaned.
hi,
Try to reset the lamp hour of your projector. For that do the following.
1. power on the projector.
2. Press the menu button
3. select lamp settings
4. Select lamp reset
5. Select yes to reset the lamp hour.
OK
Jul 29, 2011 | Dell 4100MP Multimedia Projector
I replaced bulb for Notevision PG-C30XU but how do i reset the lamp timer?
hi,
Do the following for reset the lamp hour
1.Plug the power cord into the AC socket of the projector.
2.While pressing down arrow, right arrow and ENTER on the projector a , then press POWER ON on the projector.
3."LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Feb 10, 2011 | Sharp Notevision PG-C30XU Multimedia...
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
Power on, fan runs, get a red led at the "lamp" indicator then the projector goes to standby and shuts off. Projector is a benq MP515
Hi
Check the lamp physically if looks ok then problem suspect with Lamp ballast or lamp
ANS BY
M.R. Mumbai & Dubai
Sep 01, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
What does a lamp bulb look like when it is no longer good or working? does it look burnt out? Mine looks like nothing it broken or burnt, but my projector isn't showing a picture on the screen. the fan...
look at the lamp head on. an obviously bad lamp will have cracks in the mirror, the stem can have frosty,veiny looking blisters or bubbles, the mirror can have lots of bubbles. And sometimes there are just no obvious signs.
Jun 14, 2010 | InFocus LS 110 Multimedia Projector
Canon XEED SX50 Multimedia Projector - Poor light on screen
the canon xeed sx-50 should beside its noisyness give a brilliant bright picture. if not check if there ist something wrong with the lamp? is it aged? did you buy it used? the lamp counter can be easily reset... the only reason for a faint picture could be the lamp's age or tons of dust inside the matrix :)
best
Mar 22, 2009 | Canon XEED SX50 Multimedia Projector
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
Canon XEED SX50 Multimedia Projector Logo
314 people viewed this question
old marine
old marine
