Question about Marshall MG100HDFX 100-Watt Amplifier Head
MG100HDFX Amp - crunch setting seems too loud
MG100HDFX Amp. I think there may be something amiss with the crunch setting on my amp. I set it at approx 3-4 gain on clean channel, and set master volume at approx 5-6. This works well for clean tone with my LP Custom (humbuckers) and pedals. The trouble is if I throw the crunch switch, I'm blown into the next room. There is very little adjustment available with the gain knob until you get down to the range of 0-2 (kind of defeats the purpose of an adjustment). Anything above 2 is pretty much full crunch and only the master volume can control the resultant blast. I would expect some volume increase adding crunch, but not that much. I also watched a demo video on Marshall's website and I did not see the guy adjust any volume or gain (amp or guitar) when selecting crunch from a clean setting similar to that described, with no similar blast. Any idea's? BTW, the OD channel works just fine.
  • rjivaro May 11, 2010
    Try setting up crunch first, then go back to clean and adjust that.
    Sergeant:
  • 336 Answers
I agree, Most amps, when running high gain or drive, that channel usually has to be almost all the way down on the master. After all, the gain or drive knob is nothing but a built in distortion box which also drives the volume up going into the master.
Posted on Mar 08, 2013
  • 73 Answers
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
Posted on May 23, 2009
Marshall MG100HDFX footswitch toggling - bypassing?
I once used uART & some latches to decode & hold the difference between "odd & even" midi program changes. Then used the output to switch a relay in a twin necked guitar to change between necks as it were in response to a midi pedal. Perhaps you could do something similar? Else get a Studiomaster MA-36 midi analyser & hack into it to use one piece of midi data (from across an LED?) to switch channels on your amp? Good Luck!
Jan 16, 2017 | Marshall Music
Not very loud
Try inserting a patch cable(or any 1/4" to 1/4" cord) into the effects loop jacks on the rear of the amp. If that helps you have a dirty or bad jack. A little WD-40 works wonders on corroded/dirty jacks.
Apr 19, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
I have an MG30 FX amp. In manual mode when I change channels amp seems to work incorrectly. E.g. i select clean, then set up delay. When I change to crunch then, there's no delay, though from the manual I...
Typically ONLY one effect will be active at a time unless there is a specific mixed effect available. The gain levels between the different effects are often not too consistent. In summation, this is probably the nature of the beast.
Mar 12, 2011 | Marshall Amplification Marshall MG4 Series...
Marshall MG100HDFX, VERY loud painful humming/noises as soon as the amp is turned on. Cant be adjusted by volume or anything, is this a connection problem?
Likely the filter capacitor(s) have failed OR the power amp has shorted driving DC with ripple into your speaker (very bad). Take it for repair before damage might be done.
Jan 10, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Can you tell me the correct bias setting for the marshall vba400 as i have to fit a new set of 6550 - l know how to do it but l dont know how many mV l should set it to. JIM
The nominal mv reading using a BiasProbe is listed as 34.1 for 6550 s in a 100 watt amp and the maximum is 40.9. Unless you have a BiasProbe or you have an oscilloscope, a proper dummy load and an audio sine wave signal generator I wouldn't recommend doing it yourself. If you take it to a good shop you'll get a guarranty and you won't have to worry about shortening the life of a new set of tubes. There is a great book called The Complete Guide to Guitar and Amp Maintenance by Richie Fliegler published by Hal Leonard that I would highly recommend that has the complete procedure with pictures and diagrams.
Oct 21, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
This amp used to sound great, but recently it seems like it has no bottom end. The sound has become "cheap" and lacking the warmth it used to have. What can I do to fix this?
Take your amp in and have it checked. You might need new tubes. Have it rebiased and get them to check the filter capacitors in the power supply.
Oct 15, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Feedback noise when overdrive is on
it could be your guitar pickups. try using another guitar or getting your pickups waxed at your local music store. also if your playing in a small room kind of loud, or if your using single coil pickups (like fender statocaster pickups) you will definitely get a feedback noise. if that does not work let me know.
May 10, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head Logo
635 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
