Question about Honeywell HZ-709 Oil Filled Radiator Heater
Heater shut off but doesn't turn on by it'self
I just got the honeywell hz 709 fin oil filled....i just power it up and i had set the temperature to just said 70 .....i didn't set any timer control on it but it;'s alway at 1 .....and about an hour ...they shut off ..and i thought when it's getting colder ...it just turn on by it's self but it's still off .......is there a way that i can set them soo that they turn off when they hit the temperature and turn on again by them self ...or the heater be in idle .....? or ...i had to set the control to 18 hrs ?   thanzk
  • 2 more comments
  • Lei Quan Nov 07, 2007
    I had the same problem and it turned off by itself and never turned on again.
    My email address is leiquan@yahoo.com.
    Thanks.
  • dos50 Dec 06, 2007
    I have a similar problem.  I just purchased a Honeywell 709 radiator heater and after about 1 day of use the heater just shut off on its own (I did not touch the timer button).  After cooling down I pushed the start button and the heater started up again as if nothing was wrong.
    Also, when I first started up the heater (with the thermostadt set to 74) it continued to heat up until the digital thermometer read 86.  I turned it off and then back on again, and it then seemed to work properly.
    Heater is set on the low power (600w) setting and located in a small to medium sized bedroom.
  • marada Nov 26, 2008
    I can't get mone to come on at all. Only had it two months. It was on twenty minutes and quit. I had to plug the old one back on.
  • CHESNUT1022 Jan 25, 2009
    I HAVE A SIMILAR PROBLEM, GOT IT 3 MONTHS AGO, WORKING FINE THEN YESTERDAY IT STOPPED WORKING AND WE CAN NOT GET IT STARTED AGAIN
I have model 709 and it stopped working just all of a sudden. i know it sounds kinda of silly but i shook the heater really hard and it came on so maybe try that.
Posted on Mar 03, 2010
  • fireflyfw Jan 03, 2012
    I'm having same problem, but ur solution isn't working :(
Mine shut down until i actually had th tap the on button pretty hard, then it came back on as if nothing happed
Posted on Nov 19, 2008
Do not touch the timer, once you do, it activates it. Set the temp. and leave the timer alone, unless you want it to shut off at a given time, 1 hr. and up. Once the timer shuts off you will have to start it manually.
Posted on Dec 05, 2007
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
How do we operate and turn on it i have no manual
The left button under the temperature display lets you toggle between the heat output (high, medium and low) settings. Press the left or right side of the buttons. The center button sets the timer; press the left side of the button repeatedly to increase the run time. Press the right side to lower the length of time before the heater shuts off. The right hand button sets the desired final temp. Again it's an up/down toggle on the left and right sides of the button. Once you get to the desired temperature (in 1 degree increments), the display will return to showing the current temperature three seconds after you release the button.
Home Depot has the Use and Care manual on their product site: http://www.homedepot.com/buy/honeywell-1-500-watt-oil-filled-convection-portable-heater-hz-709.html#.UMp5GTmk5G8 . The direct link is http://www.homedepot.com/catalog/pdfimages/79/79058e0a-291f-48e8-8667-ff500b3d7bb7.pdf?cm_mmc=seo'altruik'202804472 . You will need Adobe Reader or a similar program to view the document.
I hope this helps.
Dec 14, 2012 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell 709. tried to move to another room. forgot to turn off before pulling out plug. wont start. plug is ok, works for lights. wont turn on. what do i do ?
let sit overnight, most likely disturbed the internal t-stat.The oil has to settle again. And make sure power oi off before turning on.
Apr 01, 2011 | Honeywell HZ-709 Oil Filled Radiator...
My honeywell hz 709 heater tipped over slightly and now it will not come on. How do I fix this?
Hello, Usually unplugging the unit and letting tho oil settle for about an hour will reset the unit. Hope this works for you. Please reply and let me know , so if need be I may assist you further. Thank You!
Feb 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
HEATER STARTS RUNS FOR FIVE MINUTES AND SHUTS OFF,.
thermo stat saying its already heaps hot .is it turn up fully? also could be a saftey thing you know how it tips over and turns its self of mybe that sensor is faulty . if its under warranty take it back . try shaking it first
Nov 10, 2010 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
754 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
