Question about Minolta PagePro 1250W Laser Printer
Need a USED DRUM UNIT -- Complete, not just the drum!
Genuine Konica-Minolta 1710400-002 Drum Unit
EBAY!!!!!
Posted on May 13, 2009
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Drum unit replacement steps
Is the drum not part of the toner? Usually they are in a unit that slides into place but if not you may need to call an engineer to have a look
Jul 07, 2014 | Konica Minolta Bizhub 751...
Error replace drum unit konica minolta 190
You dont!!!! You replace the developer and the drum
Dec 17, 2013 | Konica Minolta Office Equipment & Supplies
Replace black drum unit - where is it?
behind the waste tone box it will be labeled K. there are also firmware and settings to cut this warning off.
Oct 19, 2013 | Konica Minolta bizhub C220 Color C / M / Y...
I want to change the setting of my drum unit on a konica minolta C-360
Enter in the service mode by press following keys:
Utility - Meter count-Check details - Stop - 0 - 0- Stop - 0 - 1 - Stop -0 -C - setting IU life stop setting and select NO STOP.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
Black drum erroe code in konica minolta 220
did you check the cartridge or a drum or its compatible or generic katun
Feb 19, 2013 | Konica Minolta bizhub C220 Color C / M / Y...
Konica minolta 7272 drum unit
Check Charging Unit and Drum Orientation position.
Try to insert by manually rotating Drum.
Jul 16, 2017 | Konica Minolta Office Equipment & Supplies
My konica minolta 2300dl tells me my drum is low. do I need toner? Where do I go to get toner?
If it tells you the DRUM is low it has nothing to do with toner, it probably meens you need to replace the DRUM unit (aluminium blue/green cylinder in the device) dont forget to reset the timer after replacement
Jan 04, 2011 | Konica Minolta OEM Konica Minolta...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Minolta PagePro 1250W Laser Printer Logo
79 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
