Question about RCA D52W19 52" Rear Projection Television
Wont turn on
Push the power button on goes green hear a click then goes off. repeated does same. unpluged for days tryed again same thing. Happened in past unplugged for an hour plugged back in and worked.
  • 2 more comments
  • Anonymous Jan 17, 2008
    I have the same problem..could be power board or a leaky tube,l either way uts gonna cost about 500.00 to fix it, but if it works great otherwise...do it...much cheaper than a new 52 inch tv for over 3000.00
  • Anonymous Feb 14, 2008
    Same problem, won't turn on, flicks the green light 3 times then goes off, was a great tv, cost $500.00 to fix, my repair guy suggest trash it, buy a new one, hesaid he won't take it to fix and sell. Great tv when they came out, but going on 8 years old. Really sucks, and I used it very little, my Dad watches his 12 hrs a day 7 days a week, works great go fiq. Paid $ 2000.00 ouch. so much for the dog and rca.
  • LEELEE37 Feb 18, 2008
    mine did the same thing,but still doesn't work...what to do!????
  • robert63199 Feb 25, 2008
    push power button tv screen goes blue for about 15 seconds then shuts off and have to wait a while then does same thing all over again. what should i try or who is a good tv repair tech that will come to house and fix already tried travis tv they did not know what problem was had to pay them 100.00 to show me how to hook rca jacks from tv to vcr that did not fix problem
  • 61 Answers
Hi ,your trouble could be a 2200 35v cap on the high voltage power supply,its in the middle of the board behind a little u shaped heat sink,the cap is green and if its bad the top will be pushed up,hope this helps
Posted on Mar 07, 2008
Tv turns on and back off
Most of these sets have a self check----if Green power light comes on for a few seconds and goes off on the front of the set press and hold both the menu and input (source) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
Let me know if you get a error code and what it is.
Unplugging power from the set clears the error code so if that has been done you will have to try to turn set on, let it fail and then do the self check again.
Dec 02, 2012 | Mitsubishi Televison & Video
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Push power button and it clicks once then green light goes out and then clicks again and then nothing happens
Do the self check the model indicated has:
When power light goes out on the front of the set press and hold both the Menu and Input (device) buttons for at least five seconds and then release both buttons.
Watch the power light closely as it will blink a two digit error code: 2 blinks and a pause followed by 2 blinks is the most common one.
It will repeat the code about 5 times and then to get it to do it again you would have to unplug the set and attempt to turn it on again etc.
Let me know what code you find and I will tell you what it means and what kind of trouble you have.
SD TECH
May 01, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
RCA D52W19 52" Rear Projection Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
