Question about Microsoft Windows Live Messanger
Error code 8e5e0408 in Windows Live Messenger, i have tried everything from editing the registry to permissions, i already had them set, so it isn't wlcomm not getting access. I cannot seem to think of a solution. Thank you.
  • 460 Answers
The only thing that I found the fastes solution is to update your msn by doing so many issues will be solve, it will take few min to downloud..
your rating is very important to me ....
Was this helpful?
Posted on May 26, 2009
8e5e0408
Exit Messenger completely (this means right clicking the Messenger tray icon and choosing Exit).
Open your registry editor (Start > Run > regedit.exe) and navigate to: for Messenger 8.0: HKCU\Software\Microsoft\MSNMessenger for Messenger 8.1: HKCU\Software\Microsoft\WindowsLive\CommunicationsClient
Once there, you must remove the following subkeys: for Messenger 8.0: Policies for Messenger 8.1: Shared
Close your registry editor and restart Messenger.Make sure you don't delete or modify anything else. Wrong alterations can cause serious problems for Windows.
For those who are not comfortable editing the registry, I've made a registry file which will do these alterations for you. Simply download the file, save it and run it:
http://home.scarlet.be/~tsf54471/msn/deletehandshakingcache.reg
or use reginout cleaner
Nov 05, 2010 | Microsoft Windows Live Messanger
Can not log on to windows live messanger
Hello.
Are you trying to log-on to the messenger on the PC or mobile?
Mar 08, 2010 | Microsoft Windows Live Messanger
Says service is temporarily unavailable, try again later. error code 8e5e0408
OK. This is a glitch in the 'program dowload" with XP.
Step 1. Uninstall it correctly and completely.
Step 2. Select RUN. DO NOT select download as here lies the glitch.
That's it.
See you in about 175MB's time.
Jan 14, 2010 | Microsoft Windows Live Messanger
Can't sign in Error message 8e5e0408
1. Hit "run" in the start menu
2. Type "regedit"
3. Open "HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger"
4. Delete the folder called MSN Messenger
5. After this MSN Messenger Live will login as normal.
or...
If you're not comfortable editing the registry, you can run this small reg. file which does the same thing as posted above:
Remove Messenger Settings
Hope I helped MSN expert Dr Reed
Nov 05, 2009 | Microsoft Computers & Internet
I keep getting Error code 8e5e0408 since I was forced to update msn live messenger can you help
If running vista or windows 7, one possible solution is to change the program so that it runs with administrator privilages AND in XP compatible mode...
Oct 27, 2009 | Microsoft Windows Live Messanger
Error code 8e5e0408 for msn messenger 9.0
Check your event logs running C:\Windows\System32\eventvwr.exe
If you see lots of wlcomm errors under Windows Logs/Application, that means wlcomm has no access to your user directory.
To solve the problem:
1. Back up your user directory under c:\Users\%username% just in case
2. right-click on x:\users\%username% and go to properties
3. go to security tab and click advanced
4. Change the permission set to the following:
Type Name Permission Inhefited from Apply To
Allow %username% Full Control <not inherited> This folder, subfolders and files
Allow SYSTEM Full Control <not inherited> This folder, subfolders and files
Allow Administrators Full Control <not inherited> This folder, subfolders and files
Make sure you uncheck the "include the inheritable..." and "replace.." checkboxes.
Click OK and let it run.
Now you should be able to log on to Messenger.
if that doesnt help
  1. Go to http://help.live.com/help.aspx?project=a&querytype=topic&query=Default_Help_PROC_MessengerVersion.htm&market=en-us
  2. Choose the Messenger version that you're using. (A new window will open).
  3. On the new window, click any topic at the left side of the page
  4. Click "Get more help" located at the bottom right part of the page
  5. Click "Get support."
thank you good luck
May 30, 2009 | Microsoft Windows Live Messanger
Error code in windows live messenger 14.0
Try to clear the cache
C:/users/%USERNAME%/contacts/%YOUREMAIL%
C:/users/%USERNAME%/appdata/local/Microsoft/Messenger/%YOUREMAIL%
Delete these two folders and then restart Windows Live Messenger.
May 06, 2009 | Microsoft Windows Live Messanger
Hi I am desperate
Please try this. Delete or rename the following directories:
and
where %USERNAME% is your username in Vista and %YOUREMAIL% is the email you use to connect to WLM.
Best regards,
Zizzler
Apr 17, 2009 | Microsoft Windows Live Messanger
Error code 8e5e0408
2. Type "regedit"
or...
Hope this helps
Mar 20, 2009 | Microsoft Windows Live Messanger
Windows live messenger error code 8e5e0408
Jan 10, 2009 | Microsoft Windows Live Messanger
Microsoft Windows Live Messanger Logo
804 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
