Question about Whirlpool LCR7244H Top Load Washer
I cannot remove the basket from the tub.
Hi, Sir, I want to remove the inner tub of LCR7244HQ2 whirlpool washing machine. Could you show me how? I need the seal 3968381 also, where can I get a good deal? Thanks. Best regards, Henry
This isn't necessarily the model you have but this manual may help. Good luck.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/81c2f31bd6afd80c85256e8d005f05d2/$FILE/COMPACTWASH.pdf
Posted on Sep 07, 2010
I am a maintenance man at U OF I and need to change the tube seal on this washer but dont know how to remove the ajatator btoolmanA illicom.net
Posted on Jul 08, 2010
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Whirlpool Calypso and I have removed the washplate, lock nut using spanner wrench and u joint assy. I want to remove the metal inner basket so I can clean all the scum inside the outer wash...
Once you remove the agitator, then the nut with the spanner wrench, the basket should lift right out. It may need a little encouragement but it will lift out. I clean the out side tub with a putty knife to get the bulk of the scum off then use some cleaner like 409, or purple power to get the rest off. BE careful around the tub seal around the shaft, you don't want to damage it and have to replace it.
Jan 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool cabrio top loading washer with corner dispensers had some coins trapped in the bottom of the basket. I can hear the coins and some water. When the washer goes into spin it apparently throws...
You have to disconnect all wire connectors, inner basket, both pumps & Then unclasp the 4 shock rods then remove the whole inner assembly. Then turn the inner assembLy upside down & every which way until they all fall out. Like shaking quarters out of your piggy bank.
Sep 28, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a 1960s whirlpool washer that is leaking out of the bleach line. I was trying to figure out how to pull the drum out of the barrel.
At this point in time it might be less distructive to go shopping for a new machine. To remove the inner basket you will have to remove the tub cover which will probably not seal after removal due to errosion of the tub. With the tub cover removed, remove the agitator which will uncover the next great feat, the hub nut which requires a special wrench to remove. If you can remove the hub nut after 40 years of corrosive detergent water you may be able to remove the inner basket if it isn't ceased on the drive block.
Feb 27, 2010 | Washing Machines
Whirlpool washer - basket will not fill with water...to a certain level and water leaks out
Sounds like the outer tub has a hole in it. Some of the newer models had a problem with the inner tub (basket) would rub a hole in the outer tub about 2/3 the way up.
Jan 06, 2010 | Whirlpool Washing Machines
How do you get the inner tub all the way out of a old whirlpool machine.
First you must remove the agitor then you see a large nut tighened down wedging the inner basket down it would be best with a spanner and hammer wrench but if careful can be removed with a flat square metal rod and hammer once unscrew pull up and out to remove
Dec 05, 2009 | Whirlpool Washing Machines
Maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Mar 09, 2008 | Washing Machines
Whirlpool LCR7244H Top Load Washer Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
