Question about Indesit WA 125 Front Load Washer
Indesit washing machine
Makes very loud noise when spinning
  • 94 Answers
First of all, what kind of a loud is it making?  Is it a loud squeak, clunk, bang, or jet engine sound?
If it is a loud jet engine sound, then your tumbler bearing is wearing out.  You could try oiling it, but [probably you will have to replace it.  It’s a big job and even if you do it yourself, the best and easiest way to do it is expensive.
I recommend first of all ordering a repair manual.  Or at least see if the parts come with detailed instructions on how to take out the old bearing and install the new.  You will probably have to replace the entire outer drum assembly.  It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster.  Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals.  In the end I wasted the money on the bearings and seals and got an new assembly.  I'd recommend just going for the new assembly and saving time.
Posted on Oct 14, 2007
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Loud clonking when on spin only when filled with clothes
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 14, 2011 | Indesit WA 125 Front Load Washer
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Dec 30, 2007 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
446 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
