Question about Dirt Devil M085580 Featherlite Plus Upright Vacuum
Belt keeps breaking on vacuum. - Dirt Devil M085580 Featherlite Plus Upright Vacuum
  • Anonymous Aug 25, 2008
    Belt burns up immediately upon replacement. If I tip the sweeper back and let it run, it runs fine. Seems like the roller brush sits flat down on the carpet creating too much resistance. What causes this?
Clean the hair off the bearings. Remove the brush. Pry off the end caps and remove the hair under and around the bearings. I used a kitchen fork.
Posted on Dec 30, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
On the roller brush take it off and where the belt sits if that is scarred any way the belt will rub see if the roller is messed up i found if u use a piece of sandpaper and smooth it out a little it should be good.
Posted on Feb 06, 2008
4 Suggested Answers
SOURCE:
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
galati2k
  • 281 Answers
SOURCE: Dirt Devil vacuum M85845 broken belts. Can't get
call all-type vacuum &janitorial supply.lisa can help you.314-275-8006
Posted on Apr 08, 2009
miket756
  • 2702 Answers
SOURCE: i keep replacing the belt
i think your talking about the motor spindel,,(the little metal bit?) if the motor is that hot its going to burn out soon, check that the brush is free to turn if its tight free it off its full of grit or fluff also check that the motor turns freely
Posted on Dec 02, 2010
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Belt keeps breaking after only short use on vacum cleaner
Each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn. The belt must be installed according to manufacturer directions for best performance, or the belt will chafe against the interior housing parts and break prematurely.Sharp debris, a low height adjustment setting or vacuuming up rug corners may cause the rubber belt to snap or wear prematurely. Check the height adjustment for the vacuum, and use a higher setting for plush rugs. Avoid vacuuming sharp objects and corners of the rug.
Jul 27, 2011 | Vacuums
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
Belt keeps breaking
in some cases when you by a belt from the brand stores the belts are not always to spec's. for example: you pick out the belt that's for your machine you go home and put it on and not even 5 to 10 mins. the belt breaks, thats because the spec's or not at the company's spec's and they break fast. take the same belt from the company and you will notice that the belt can be stretched alot more and is easier to put on. if you put on a new belt and it still breaks, first see if the brush or agitator can move freely. if not then the agitator needs to be replaced. ( fyi : the agitator end caps need to be taken off and cleaned for dirt or hair that gets twisted in there)
Aug 02, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
My Eureka Boss vacuum belt keeps breaking
I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
Jul 03, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Why does the belt keep breaking as soon as I turn on the vacuum?
Hi Have you got the correct belt? If its breaking then the brush end caps or something is clogged. If you can get into the floor head ensure you look at the actual brush roll to see if there is anything is clogged or trapped. Remove all matter of dust and see if that works.
Mar 23, 2009 | Eureka 431A Optima Bagless Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Generic problem for all Vacuums
Posted by andy78billy on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
The rubber band that turns the roller on the vacuum keeps breaking. I just bought a new rubber band, put it on, and it broke immediately. Can it be fixed?
I see there could be 2 problems – either your revolving brush has hair or thread buildup in the ends of the brushroll of which is causing the belt to break and would need to be cleaned out, or check the bearings on each end – they could be **** as well, or the motor shaft or motor assm is not tuning freely and in that case the motor should be replaced and it is not the belt – one other thing is to make sure the motor is in there securely. Once you get the belt on then roll the pulley and the belt together to make sure the belt is on correctly if the brushroll spins freely.
Apr 18, 2008 | Vacuums
Dirt Devil M085580 Featherlite Plus Upright Vacuum Logo
364 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
