Question about Hoover HTC243 Top Load Washer
Hoover 600mb 6.0 kg top load washing machine (not as below)
My top loader fills will water fine but wont start actually washing the clothes. If you manually turn the dial it eventually starts to work around the empty water cycle before the spray rinse cycle. Please help ASAP as i need some clean clothes. Getting desperate.
  • 3 more comments
  • Anonymous Mar 16, 2014
    my top load fill will water fine but wont start cycle washing the clothe it manually turn to the spray rinse cycle itwork fine
  • Anonymous Mar 21, 2014
    Only some programes are working now, but even if I get clothes washed the water wont drain away
  • Anonymous Mar 22, 2014
    the rinse cycle water level in my top loading moffat washing machine barely covers the clothes and sometimes dosent and clothes are not properly rinsed\
  • Anonymous Mar 23, 2014
    width of washing machine
  • Anonymous Mar 25, 2014
    Fills with water but does not go through wash cycles or [pump out water
  • 351 Answers
Timer or timer module fault
Posted on Mar 02, 2008
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
Electra 535 Dual Spin - I`m trying to discover what the capacity of this machine is, the manual supplied with the machine gives all spec.s apart from its size. ie is it 6, 6.5 or 7. kilos...
From what I remember, the 535 is a 5.5 kg machine. The best way to load any front loader is to have the tub full but not packed. Its the safest. As for weight capacity, due to Australian Standards testing, machines have to state what load they will handle with a certain volume of water and power usage, but any front loader, load it up but dont pack the clothes in and you will have the best efficiency. By the way, the clothes are measured dry weight..
Jul 31, 2011 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Hoover 550M washing machine - taking ages to fill, water is just dribbling out. Was fine when started, lifted lid to put in clothes and now only dribbling out. Water pressure in rest of house seems to be...
Check the inlet screen on the hose connection on the back of the machine. This may be clogged with debris, also make sure you hose is not crimped. You can unhook the inlet hose and put it in a bucket and turn it on to see how much water is actuall coming thru that hose. I suspect some type of blockage in the inlet.
Nov 11, 2010 | Hoover HTC243 Top Load Washer
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Top loader 600MB fills water but wont wash or spin.Water fills to right level and timer turns o.k.
Check the lid switch for proper operation. If the switch is bad or not being actuated by the lowered lid, it will block operation of the machine.
Oct 20, 2009 | Hoover HTC243 Top Load Washer
Hoover 600mb doesn't spin dry. Clothes just sit in the machine without moving. Water empties OK, but clothes are dripping wet.
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Sep 03, 2009 | Hoover HTC243 Top Load Washer
Hoover 600MB Top Loader, Won't Spin
I have the same problem. Just started missing the spin cycles and now I need to find which part to replace.
So far I think it could be: Aged contacts in the Timer, a faulty spin/no spin switch, or something to do with the brake/release mechanisms etc. ..I do know that the problem is electrical because everytime the motor starts the spin works fine; therefore eliminating in my opinion, the mechanical gearbox bits as a cause.
Jun 22, 2009 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
1,297 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
