Question about Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard
Soltek m b
When I turn on the power only the fan comes on. power is to hd, dvdr. no post audio beeps, prior to this pressing power button, system came on after several attempts to power it up. also prior to this series of continuous beeps, now nothing cant access cmos, tried switching jumper on bios. no video nothing! any solutions? sam
  • mmwmosa Oct 14, 2007
     sorryi try that but nothing
  • mmwmosa Oct 15, 2007
    i do it alot of time but nothing
    what about bios i think it lost from chip
    thanks for quick anwser
    Scholar:
  • 116 Answers
Sounds like your memory.
How many sticks do you have in it?
Try removing all but 1, or moving that 1 around. You'll have to reset the bios and let it set without power for about 5minutes, between each try.
Posted on Oct 14, 2007
  • Charles Fields
    Charles Fields Oct 15, 2007
    Why dont you answer the questions... not just jump to 'nothing can be fixed'!
  • Charles Fields
    Well i think i'm finished. You all ready gave a negative rating so no reason to try to help you.
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
1 long beep, 2 short beep
You have a bad RAM, install just 1 module and try, is doesn't swap the memory module and try again.
http://www.gigabyte.com/support-downloads/faq-page.aspx?fid=816
I have a CECHA01 model (60 gb) PS3. Lightning recently messed a few things up which includes the PS3 (yes i was using a surge protector). Every time I start the system the fan gets really loud for 6-7...
Okay, hold the ps3's power button until it shuts off. Then hold it again until it beeps twice. When prompted, plug your controller in. Press the PS button on your controller. Now, dpad
Jul 20, 2011 | Sony Playstation 3 (PS3) Console
With power button push in the light comes on and fan comes on but in 5 seconds it turns off. I've tried with battery out and just with power plug , still the same results.
Can be one of the following
  • Remove battery and power lead - press and hold the power ket for 60 seconds. put in power lead and it may start.
  • If you are getting beeps or lights flashing then you have a Power On Start up Test (POST) error. This means you have a hardware failure in the system. The actual error depends on the motherboard and the error beeps. Solutions vary depending on the error, can be from replace memory to motherboard is shot. Please let me know if you are getting beep codes, this may need professional repair.
  • Does not start and no beep codes, then the power or the motherboard has failed, this will need professional repair.
Jan 19, 2011 | Toshiba Satellite M65-S809 Notebook
Hi. my CPU (system) does not start. When i press the power button, the light turns on for a second then nothing happens.
Does the power supply fan spin when you switch it on ??
Do you hear a"posting" beep??
Does the CPU fan start to spin??
If no to all of these probably dud mobo.
Dec 21, 2009 | Intel CPU
What does No Power/No POST Troubleshooting mean
Hi.
It refers to two symptoms. No power just means the machine is dead and nothing happens when you press the power button on the computer. POST stands for Power On Self Test. This is what happens just after you press the power button - the computer checks devices connected to it then starts to load Windows or whatever operating system you have. If the computer is dead, then it is often caused by a faulty power supply (metal box where the power cord goes in. If it won't POST then an error may be displayed to tell you where it stopped during POST, or error beeps may sound to tell the technician which part of POST has failed. Sometimes, you may hear the fans and hard disk, but the monitor stays dead. This is usually caused by the RAM coming loose in it's socket or the video card coming loose/ failing.
Mark
Jan 22, 2009 | Computers & Internet
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Two long beeps and no booting. Motherboard Soltek SL-75FRN2-L. The computer has worked with this motherboard for about 3 years. The problem started like that: first problems with the hard disk with the...
You could try re-seating your ram and your video card if applicable.
2 beeps generally upon post depending on the bios is video or unstable ram.
Depending on how many sticks you have on the board try re-seating them if that doesn't work diagnose the faulty stick by putting them in 1 at a time.
Hope this helps
Jan 19, 2008 | Soltek SL-75FRN2-L Motherboard
Pc-chip m957g
sounds like the motherboard has failed. I had those same symptoms this summer. Replaced m/b and it's good again.  Did you count the 'continuous' beeps? That's a code to say what is wrong.
Oct 14, 2007 | Pc Ware PC CHIPS: PC-Chip M957G...
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard Logo
74 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
