Question about Ryobi Garden
Electric trimmer will not start - Ryobi Garden
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
Electric black and decker 14 grass hog won't start
spray the contact area on the weed trimmer with some contact cleaner WD 40 will work also
Mar 30, 2015 | Black & Decker Black and Decker & Grass...
My Bosch AHS 45 16 electric hedge trimmer start, is there anything you can suggest?
Hi Dan Walsh, When an electric motor won't start, it could be an open temperature device in the winding of the motor itself. If you have brushes and they are worn, then one or maybe two of the brushes can't stay inside the brush holder. They are spring loaded and if worn out can pop out. Also, if the winding are open, then there is not continuity. This will cause the condition you described. Not the best news, but it might answer your question.
Good Luck!
Jun 03, 2014 | Bosch AHS 45-16 Electric Hedge Trimmer
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
The pull cord on my ZR29550 string trimmer is stuck in the fully retracted position. I can't pull it to start the machine. Also the electric starter can't turn it over.
well its not going to start with electric because the cord is out of it...
just take it apart becareful do not pull the recoil out or your in a mess....
but this should help you out if you need to know more just ask...
Aug 18, 2010 | Ryobi 15" Electric Factory Reconditioned...
15'' electric string trimmer start/stops
IF it humms but not turning then it may be jamed.
If it dose nothing it may have a lose connection on the inside of the housing /cable jamed on seal joints when made over time this will break and so leaving you with an non working plastic shell.
Aug 16, 2009 | Garden
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
20 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
