Question about LG enV VX9900 Cellular Phone
I cant hear anyone nor can they hear me during a phone call
My phone somehow got water under the battery and there is a red dot which im assuming idicates water damnage. now when i go to call someone i cant hear them nor can they hear me. but when someone calls me, my phone rings normal, but again i cant talk or hear them. and when i go to watch my videos there is no volume. is the phone permantely damaged?
  • Anonymous May 13, 2009
    I have the same problem but my phone did not get wet. This just started out of no where. I had just used my phone 45 minutes earlier and then it stopped. Confusing part is that I can use my headset.
    Any ideas or thoughts?
    DC
  • scrtslsmn May 14, 2009
    I dropped my ENV in soup (very original)... the txting works but the phone doesnt.. I can txt all day... but if I get a phone call... no go.... I have had it drying in my car in the sun for about 3 months... Im'a give it shot when I get home... the screen works.... txting.... I can still play games.... it just no longer works for the purpose instended....
Sorry but no water has gotten to it nut thsnk u kindly
Posted on Mar 15, 2015
    President:
  • 788 Answers
Once water gets inside the phone there is not much you can do about it. If you want you can try what I have done for my daughter many times with good results. Remove the battery, this will help a great deal. Just having the phone powered up is not a good thing while it is wet. After removing the battery allow it to air dry, you can use a hair dryer to speed things up, but be careful not to get the phone too hot. I hold it in my hand and that keeps me from getting it to hot.
Leave the battery out for as long as you can, days would be better than hours. Then put the battery back in and see if the moisture is out of the phone. If this works you are good to go, if not then your phone may be beyond help because of the water.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for you support
Posted on May 12, 2009
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
How do i find out if the motorola cliq im going to buy has had water damage?
when you pop the battery off there is a circular dot near the middle near the orange or black rubber thing that helps lock the SIM in and SD card.
The dot is likely either white or red. White should indicate that it is good and red if it had significant moisture/ water contact.
Apr 01, 2010 | Motorola Mobility CLIQ Cell Phone
Motorola razr has red dot inside phone
The phone has gotten wet somehow.......
Remove the battery!! Let the phone sit in a warm place for several days. Keep checking once a day or so to see if it will work. Always remove the battery while drying. If after a few days of drying it still is not fucntioning, it's wasted!
Nov 27, 2009 | AT&T Motorola RAZR V3 Pay-As-You-Go Cell...
When I receive calls I do not hear the person but they can hear m
when i had a phone like that it had water damage. take out the battery and look for a red dot on the back.. it is supposed to be white but if it is red or pink-ish then its water damaga.hope i helped.
Apr 07, 2009 | Samsung BlackJack II Smartphone
Slight water damage
Don't have a soulution if you don't want to go to the provider. Enless the dot that is on the back behide your battery isn't red then you don't have water damage some things just happen. If it isn't i would take it in seeming you just got it.
Feb 02, 2009 | RIM BlackBerry Pearl 8100
Phone will not turn on
ok, take out the battery and look and see you can see a white dot pice of circular paper, if it is red, your phone somehow got water in it, look at your battery(white dot paper) if it is red than you have water in you phone. now you need to dry it! leave it on your car dast board in the sun 24hrs or use a hair dryer ( use low heat) you must dry your phone and battery completely before the next step, Next step- find a good working battery and insert it in your phone, see if this will correct your problem, sometime the battery volt are very low or maybe the battery itself its bad, but make sure you put in a new battery to test this out, don't pay for the battery until you check you phone at the counter, ask for the right model for you phone.
good luck
z
Nov 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Wet phone
Unfortunately you phone has water damage, and your warrenty does not cover that. For your information, either behind the battery, or within the casing, there is a white dot, and when the white dot turns red the service provider knows that your phone has been in contact with water. Your two options are to buy a new phone, or to wait it out and hopefully your phone will air dry and everything will work ok.
Sep 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Water Damage
this is a stick and whens it get wet it change color into red.dont be worry is nothing
Aug 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
LG enV VX9900 Cellular Phone Logo
167 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
