Question about RCA HD52W58 52" TV
When I turn TV on it comes on then blinks off three times. Then locks itself out... So I have to unplug for 3 - 4 hours... Sometimes it comes on and works normal and sometimes it don't..
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
  • 1694 Answers
SOURCE: Turns on and off at all times of the day and night
Microprocessor or EEPROM circuit = difficult repair,could be
expensive......T.
Posted on Oct 24, 2007
SOURCE: power turns on and off by its self
The problem is the key board controller is malfunctioning. I have contacted a multitude of supply houses even
RCA included and I have not been able to buy the part. However, you can bypass the problem by disabling the key board functions by activating the parental control item, not the password, by using the remote. All the keys on the front panel will be disabled but you can still operate the tv with the remote plus save yourself a cost on parts and labor.
Posted on Apr 13, 2008
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Posted on May 28, 2008
  • 77 Answers
SOURCE: RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Posted on Feb 24, 2009
Rca flat panel tv turns itself off. LED light on pwer button blinks 3 times,but wont turn back on
With the model which is not indicated here Google that for 3 blinks to know what the error code means.
Dec 23, 2012 | RCA Televison & Video
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Hi, I have a Sony KDL-46XBR9 LCD Digital Color TV. This morning my son was watching cartoons and it clicked itself off. It has sometimes done this in the past, so we did something else for a couple of...
This tv have a power supply board is the causes and the problems.Ur tv power supply board finally gave out and not supply the right voltages to the tv system anymore.That the board,where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Televison & Video
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Tv turns itself off after 5 seconds...blinks 7 times?
Had the same problem. Unplug from wall for 36 hours and then it works.
Hp Sydney Aus
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KV-40XBR700 turns itself off, standby blinks 5 times continuously
http://esupport.sony.com/US/perl/model-home.pl?mdl=KV40XBR700&LOC=3 Ok this isn't the best answer in the world but from here you can find a service tech in your area that works on Sony products. Good luck!!!
Nov 19, 2008 | Sony KV-32V40 32" TV
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
RCA HD52W58 52" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
