There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
step one check fuse located in control panel . next step the control pc board inside the unit should be a paper schmatic with control board part number. enter part number on ebay . most of the time the control board goes bad its usually about 150.00
You have to program you new board. I think you enter into the t01 mode and then select the number that corresponds to your model dryer. Here is a link for the manual that shows steps to replacing the control board. http://www.applianceblog.com/manuals/31-9136_GEFDryer.pdf
The main fuse is the probable cause, magnetron, "heart of the microwave oven" the inverter board, "if 7 years old or less" and the keypad control board can be a factor.
The clicking behind the refrig , is comming from the main control board , behind the 8" X 10 " panel . The part number is WR55X10656 . The compressor relay , on the board has burnt . Yes , your freezer is thawing , due to the clicking .
