Question about Garden
Does the gx 340 have a timing belt. I have a honda 1011 riding mower that backfires when trying to start, the fly wheel sheer pin is ok.
  • 86 Answers
What engine do you have ? Some have a selonoid on bottom of bowl of carburetor if bad can cause your problem.
Posted on May 13, 2009
TRY TO START BUT BACKFIRE THRU CARB AND WONT START AT ALL
roger, try a new spark plug, i just fixed a John Deere that took two days only to find out that the new plug out of the box was a bad plug. also check the fly wheel key , it may have sheered off.
Sep 24, 2015 | John Deere Garden
Engine backfires will not start
check your oil make sure there's no gas in the oil, if no gas in oil then check your fly wheel key make sure its not sheered, let me know what you find
Jun 06, 2015 | Garden
Riding Mower Backfires
suonds like you have a timeing problum could be cupple of thangs # 1 could be you have a bad keyway in your flywheel or your fly wheel is cracked that is what i would check
Mar 18, 2014 | Craftsman Garden
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
Kohler engine backfires but does not run
sheer pin on engine shaft is busted. take off the fly wheel and look inside or on the shaft.
Sep 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Poulan Pro push mower with a Honda engine that is leaking oil when it runs. Its model number is PR55N22SH It is three years old and never had a problem until now. any ideas where to start?
This mower sounds like it took a hit at one time and perhaps bent the blade, shaft?
If you had to replace the blade because it in fact did hit something then you would also want to be sure the sheer pin is ok, that is an easy test.... it goes like this, does it pull smooth when you are trying to start or does it backfire, shake, run raggy and at times want to pull your arms out of their sockets from the kick back?
Before checking the sheer pin you must determine if the shaft is bent(the shaft supports the balde) Raise mower off the ground, pull the spark plug out of the cylinder and turn the shaft, does the blade hit the casing underneath, if it does you are either buying a new mower or paying a lot to repair this one.
Also if any or all these situational events happened to the mower it is safe to say that the shaft oil seal is leaking on the bottom of the mower, remove plug and remove blade, inspect seal just above where the blade sits, its a round pressed rubber lipped seal around the shaft.
If it does all that then you need to pull the top cover and pull cord plate off the mower, take off the 3/4" nut left loosens, and check the sheer pin, its in the 1/4 wide x1/2 " long groove going down the shaft just below where you removed the 3/4 " nut, if its worn or partially worn pull the aluminum looking round cover off using a soft tap with a hammer to remove or a wheel puller and take the old sheer pin to Ace or the like hardware to match up a new one, install using the reverse proceedure, tighten the 3/4" nut to about 50 ft. pounds. Happy Mowing!!
Jun 11, 2010 | Garden
Will a honda engine gx 340 11 hp engine fit
no it will not fit unless some modifications are made
Sep 13, 2009 | Garden
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
