I have a 1997 Eldorado and the heat and defrost does not work. Some times I may feel a little heat after driving but I think that is just coming from the engine. Also is it says low refrident and check ac comp. Im not worried about ac. The blower seems to not come on. Where do I start?
SOURCE: blower not working on ac or heater etc.
A very common solution here is replacement of the blower motor resistor. The resistor when they break do one of two things.
A. work only on high
B. dont work.
This item is located on passanger side under dash and is usually held in with two small bolts on either side with an electrical connector seperating the mounting screws. It is mounted right in the air box. I replace at least one of these a week in my shop very common item.
SOURCE: Blower for AC/Heater stopped working
hi
my heater blower has stopped working all together i have checked all the fuses but do not no where the relays are for the heater.
SOURCE: heater blower install for 1997 cadillac eldorado
The solution is more than likely a new blower motor. Replacing this blower motor is no small task. I am in the process of doing it, but there is so little wiggle room that I suspect that if a cadillac mechanic does this job, they will jack up the engine/transaxle to make room. The motor itself is not cheap either, a replacement Delco is well over $200. I will let you know if my new motor install works.
SOURCE: Heater/ac not working properly
buddyinstl is is right. the same thing happened on mine. the heat controls would not work either i tried to turn the heat down but the air would not get any cooler until i put this tube back on.
SOURCE: 1997 dodge intrepid heater/ac fuse keeps blowing
I have a 96 Intrepid, and none of the signal lights work. I tried replacing the fuse, but this did not remedy the problem. Could this be a loose connection?
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
This will help.Thanks.
