Question about Lexmark X1270 All-In-One InkJet Printer
How do I adjust the color quality of my Lexmark 1200 Series printer. The colors are all off. When I print the test page, the Yellow is almost non existant, and the orange is faint at best.
  • hlcLexmark May 11, 2010
    If yellow isn't jetting, most other colors will be affected, as they use some yellow.
    Does the printer or software report that color ink is low? If so, replace the color ink cartridge.
    If it doesn't report low ink, try cleaning the cartridge. Here is more information:
    If the printed bars in one color fade on either side of the page or are shorter than the other bars, the cartridge is running low on ink of that particular color.
    If there are thin lines running through the bars or if the diagonal lines at the bottom are broken, the cartridge may need cleaning. Follow these instructions:
    1. Remove the problematic cartridge or cartridges from the printer.
    2. Take a warm damp paper towel and set the ink cartridge right-side-up on it so that the ink nozzles are against the towel.
    3. Hold the cartridge in this position for about 15 seconds.
    4. Wipe the printhead (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
    5. Next, dab the cartridge on the towel to make sure that the ink is flowing.
    6. Use a clean part of your dry paper towel to make sure that the cartridges are dry and then snap them back into the printer.
    7. Select Old Cartridge install in the software.
    8. Repeat the Clean Nozzle Page test one more time.
    9. If the problem persists, you may need to replace the cartridge.
    Problem Solver:
  • 5 Answers
Have you tried printing alignment page after you installed a new ink or cartridges if you did not try to print an alignment page first
Posted on May 15, 2009
Scanning Pink
It could be due to your color cartridge. Try to do the clean cartridge function using the printer software on your computer.
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 1200 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Try to scan again to verify that the print quality has improved. If not, try to replace your cartridge.
Mar 04, 2012 | Lexmark X1270 All-In-One InkJet Printer
My printer does not acknowledge presence of ink cartridges.will only print in black
It could be that the color cartridge is not seated properly or just needs cleaning.
Try to re-seat your color ink cartridge. Open the printer cover > remove the color cartridge > re-insert the color cartridge and make sure it's properly seated > close the printer cover. Try to print again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  2. Go to Programs.
  3. Go to Lexmark Z600 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 04, 2012 | Lexmark Z600 InkJet Printer
Blue and yellow not printing
Just make sure you are inserting genuine Lexmark cartridges. Lexmark does not recommend the use of refilled, remanufactured or clone cartridges, you might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try cleaning the cartridge nozzles using the Lexmark software installed on your computer instead:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark 2600 Series folder.4. Select Lexmark Solution Center.5. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean it from dirt and possible clogs.
Should the problem continue, please contact Lexmark Technical Support Center to have your genuine cartridge replaced. They might ask for your receipt so have them ready. If you're not using genuine supplies, please replace your cartridges with original supplies.
Dec 27, 2011 | Lexmark X2670 All-In-One Printer
Color cartridge not recognized wont print in color
Try to re-seat the color cartridge in the printer. Open the printer cover > remove the color cartridge > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridge and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle or one of your cartridges is not seated properly in the carrier. Please follow the steps below to identify and fix print quality issues with your model:
  2. Go to Programs.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the print cartridge nozzles and clean them.
Oct 07, 2011 | Lexmark X2600 InkJet Printer
Have color cartridge in, bottom tab removed and printer will not print in color
Print quality issues could be due to clogged cartridge nozzles. Please follow the steps below to clean the print cartridge nozzles:
  1. On your computer, go to Start > All Programs / Programs > Lexmark 1200 Series > Lexmark Solution Center.
  2. From the Maintenance tab, select Clean to fix horizontal streaks.
  3. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them.
  4. Try to print again.
Jul 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Brother inkjet printer (DCP-585CW) is not printing yellow colour.
If the yellow ink is not printing here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
Apr 03, 2011 | Brother DCP585cw AllInOne InkJet Printer
My lexmark x1240 will not print in color
After disconnecting the cables from the printer and restarting the computer I would suggest removing all printer related software from Add/Remove programs in the Control Panel. After that I would suggest downloading the latest drivers by following the directions below.
You should be able to get the drivers here. Just enter your exact printer model in the Search by printer model field and press Enter.
Click the Download Driver link and choose your operating system in the Select Windows field. Then on the next page, choose the Download Now link on the right.
On the next page you may see a yellow security banner at the top of the browser. If so, click it and choose Download File. After that, choose Save to start the download. After the download completes you can double click the file to start the installation.
Hope this helps. Please remember to rate this information.
Thanks
Jan 04, 2009 | Lexmark X1240 All-In-One InkJet Printer
After replacing the ink cartridges ran out I replaced them for new ones and the machine is not telling me that cartridges are empty tried and tried to rereplace them and I still keep getting the same
  1. Press the Menu/Set key.
  2. Press the up or down navigation key until TEST PRINT appears on the LCD.
  3. Press Fax Start. The DCP/MFC begins printing the Print Quality Test Sheet.
  4. By reviewing this Test Sheet, you can determine if the print quality or alignment needs improvement or adjustment.
StepA - Checking the print quality:
  1. The display will read "IS STEP "A" OK?" 1.YES 2. NO.
    Before choosing YES or NO, closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and proceed to StepB. If you can see missing short lines, press 2 (NO).
  2. The display will then ask you if the print quality is OK for each color. Press 2(NO) for any color with the problem.
  3. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1(YES) and the DCP/MFC will start cleaning the color ink cartridges.
  4. After the cleaning is finished, press Fax Start. The DCP/MFC will print another Print Quality Test Sheet.
  5. If you can see missing short lines in any of the four color blocks press 2 (NO) and repea the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
StepB - Setting the Alignment:
  1. The display will then read "IS STEP "B" OK?".
  2. Examine the 600 DPI and 1200 DPI test prints on the Print Quality Test Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1(YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  3. Print another Print Quality Test Sheet by following the steps provided at the top of this page and check it.
  4. Press Stop/Exit.
Aug 11, 2008 | Brother MFC 420CN All-In-One InkJet...
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
Brother MFC-620CN All-In-One Printer
A service partner has to adjust the printhead by special software. This cant be done by user. After adjustment the printing quality will be as good as brand new.
Apr 26, 2007 | Brother MFC620CN Home/Office Color Inkjet...
Lexmark X1270 All-In-One InkJet Printer Logo
179 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
