Question about RCA HD52W59 HDTV Projection Television
Which parts do I need to fix convergence for
Which parts do I need to fix convergence for hd52w59
  • peanut_1119 May 12, 2009
    can I complete this component switch myself or will I need assistance. I like tinkering with things such as thi but what do I need to do to drain the current from the set so not to be shocked to death during the processs.
  • 6,784 Answers
Ok, the individual parts that are located on this board are not available at this time but, you can order a complete board that will have all new parts already soldered and ready to be inserted into tv. the actual IC you will need to repair this board is also unavailable.
I recommend purchasing the entire convergence board. this is actually the only option you will have, considering, the unavailability of the individual parts you seek. this board replacement is not an easy job and if not done correctly, can cause serious injury and lose of additional components within the TV.
If you choose to do it yourself, i would advise to have ample knowledge of the RCA board layout and design. A assistant would be a good call as well. You can drain all power by unplugging for 5 minutes before you attempt the board transplant. I will post the need BOard below. you can purchase the board at the link as well if you choose.
CLICK HERE FOR YOUR REPLACEMENT BOARD(CONVER)
Please rate and god bless:)
Posted on May 12, 2009
  • 431 Answers
As it is that you wish to try this yourself and I do understand the reasons and the economics of this I think I should point out , each tube in this system carries a charge of at least 19.000 volts whilst operating . When turned off it holds a charge within the tube of approx 2000 volts and that is minimum they act like a capacitor and release the charge very slowly . To sucessfuly adjust the convergance manualy by adjusting the tube scan coils the set needs to be LIVE and this is a job for a qualified engineer . It also requires the use of a device called a crosshatch generator that puts a pattern onto the screen so all lines can be converged . at this time a system called pincushion will also need to be adjusted to bring the horizontal and vertical scan into parabolic shape . so if the auto convergence in the menu is not working it is possibly because the tubes need replacing if the set is in continual use ?. the best thing to do is seek an engineers assistance it may save more than money .. Regards Vortash
How to fix my RCA HD52W59
These are tough sets with this problem.
Most sets for Convergence use a single fairly simple circuit but this one parts are spread across 3 boards--not conventional in any sense.
The parts are also special---RCA only---This problem in these is so extensive all you have to do is GOOGLE the model number with "convergence" to see how common it is.
These sets were so poorly made, parts and technical support does not exist that many shops (including the one I work for) resist or even refuse to fix them.
Mar 25, 2012 | RCA HD52W59 HDTV Projection Television
Convergergence ICS RCA HD replacement
depending on the model, But most RCA rear projections do not have ICs like most other brands but if the convergence wont adjust the convergence power board will need replacement. You can get any part and free assistance from www.tvrepairworld.com so you can fix the issue.
Jan 04, 2012 | RCA HD52W59 HDTV Projection Television
PICTURE IS OR HAS RED/BLUE/GREEN LINES
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59, Convergence is out, not even on set up menu, and also the picture is bowing. how much to fix or just use it for target practice
you can fix it for 24.00. You can get the ITC222 & ITC222A convergence option missing repair kit at the following link which contains the parts and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 14, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 28, 2009 | RCA HD52W59 HDTV Projection Television
Convergence
in the tips and tricks section under ther fl231 article. This article explians why this fuse fails and how to fix it. it is my belief that is is bad solder connections.
Nov 17, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Projection TV
Convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
245 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
