Question about Fargo 4250 Thermal Printer
Fargo 4250 card printer runs, but doesn't print.
Bought a USED Fargo 4250 card printer. Cleaned it; installed new full color ribbon; adjusted it so that card jams and no-feeds were eliminated. Ran self-test print - cards run through; display says printer is printing; cards come out blank. Suggestions?
  • 526 Answers
Take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
Posted on May 31, 2009
If you see the image or text on the ribbon but nothing on the card and you have already tested the head lift motor try one more thing before you order a print head or start opening the assembly.
when the display shows printing (different colors) take a look in the output slot and see if you see the card moving back and forth. If not check the roller on the bottom changing that one or just cleaning it should resolve the problem.
Posted on Oct 14, 2009
I have Fargo DTC550 ID printer printing double image can someone help
Hi Arthur -
If by "double-image" you mean that you see multiple identical images printed, but each is slightly offset and appear in yellow, magenta, or cyan ink colors, then it seems like the card is slipping within the printer as it prints. These printers print 1 color at a time, with a total of 5 passes to complete 1 card image - 1 pass each for the yellow, magenta, cyan, black & clear overlay panels of a standard YMCKO ribbon. If the card doesn't get positioned properly for each new panel on the ribbon, then the subsequent image will have a slight offset to it.
The fix could be as simple as a thorough cleaning - with supplies from a Fargo dealer (like us!) that are appropriate for that model. It could also be that the printer requires a ribbon-sensor calibration. To do this, you could need to download the Fargo Workbench Utility program from the HID Global website here: (Drivers Downloads) . There is a "Printer Information" view in this utility, and then a "Test" you can run called "Ribbon Calibration" - do it regardless of the cleaning.
If still not resolved, contact us or your Fargo dealer for further support.
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com/
Nov 17, 2017 | Fargo Office Equipment & Supplies
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
Ribbon out error
you can try to recalibrate, it might help. take the ribbon out, close the printer, go to the drivers, go to the sensor area of the drivers, and select calibrate.
Nov 21, 2008 | Fargo Persona C16 Thermal Printer
Color print out of place
Assuming you are asking about colors out of alignment, usually this is due to the card slipping and returning to the corrent position in each pass. I have corrected this problem by thouroghly cleaning all the rollers with an alcohol wipe. With the cover open and the ribbon removed, firmly hold the wipe against the two gray and one black roller while depressing the forward and reverse [power & online buttons] and allowing the rollers to run several revolutions against the wipe. I just use typical medical or first aid wipes, no need for fancy equipment wipes. The alcohol rejuvenates the rollers and keeps them sticky so to speak, so the card is moved correctly. To clean the feed roller, send a card or self test from the driver to the printer with the cover open and the ribbon removed. While you are at it, use a wipe to com[letely clean the metal interior of the printer. Cleanliness is next to godliness when it comes to these printers. ~ Jon
Jul 16, 2008 | Fargo 4250 Thermal Printer
Fargo 4250 driver
You could try to install the XP drivers by running them in compatibility mode on Vista. It might work
May 05, 2008 | Fargo 4250 Thermal Printer
Wrong ribbon messages
Your printer ribbons sensor maybe broken or you could have a main board problem. Call Realstar Solutions 800.554.9111
Oct 16, 2007 | Fargo 4250 Thermal Printer
Fargo 4250 Thermal Printer Logo
397 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
