Depending on what you are connecting to your HDMI inputs, rotating the input selector on the front panel (or one of the input selector buttons on remote), to which you've assigned the component on HDMI 1 or HDMI 2 on the back panel should give you the connection. Make sure you have an HDMI component connected to it, and that you're using its HDMI out connector (eg. output of DVD to input on your Yamaha). Hope this helps.
SOURCE: From a samsung dvd player HDMI output to the
Did you connect all the cables correctly? Did you put, for example the white cable to the white socket, etc ?
SOURCE: yamaha rxv1600 speakers keep cutting in and out when i turn the volume loud
The most likely cause is the audio output semiconductors gets to hot, or bad solder connections, but if you run the volume at half to three quarters the amp will start to clip drawing more power from amplifier the outputs will go into thermal runner way causing a shutdown.
