When it fills and drum starts to turn it trips the fuse
Either you dont have a high enough amperage breaker or the motor is going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008
Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
SOURCE: washing machine motor not turning
hello,
what this indicate is that there have been a power disconnection from power supply on the jet string connected to the drum (drum controller)
what you will have to do to solve this problem is to unscrew the the washer then trace the wire down to the jet it is round in shape at the back of the washer
please rate this
thank you
