Question about Polaroid FLM-323B Television
WON'T TURN ON UNTIL THE POWER IS INTERRUPTED AFTER MANY TRIES
It takes 7 or 8 tries to get the TV to turn on. Once on, it stays on and works great. The remote doesn't turn it on any more and we must interrupt the power several times in order to get it to turn on.
  • rogerlschmit May 12, 2009
    THE ON-OFF SWITCH DOES NOT WORK TO TURN IT BACK OFF. THE POWER SWITCH TURNS THE BLUE LIGHT ON BUT I DISCONNECT THE POWER BY UNPLUGGING IT TO TURN IT OFF AND THEN BACK ON AGAIN BEFORE IT COMES TO LIFE. I AM NOT ELECTRONICLLY TRAINED.
  • 431 Answers
How do you interupt the power from the plug or from the on off switch .. Either way it might be a dry joint that is causing this .. as the joint arcs it will cause a connection a spark weld as such on the solder when you turn it off the solder cools and then contracts braking the connection so you have the same problem again .
If you are electricaly trained I would suggest that this is what you look for .. however if not then I would advise that you seek an engineer to do this as there is the possibility of causing more harm than good . Untrained personel should never work on live equipment and all safety precautions should be adhered to . .. hope this is of help......Regards Vortash
Posted on May 12, 2009
  • clive pearson
    clive pearson May 13, 2009
    Very strange fault this , I can think of possibly half a dozen faults it could be for instance ..Corrupt processor IC not sending the dissconect signal to the switch mode power supply to turn off .
    Actual faulty on off switch possibly depending if it is a power cut off switch or merely a signal switch ( connects momentarily to tell the IC to turn set off or on ) without seeing a schematic I couldnt be sure . dry joints as I said earlier , and you say that the remote doesn't work it s surely pointing towards an Ic failiure .. or a corruption of the software in the IR controler IC sorry I think this is one that will need Bench testing to find out for sure .. sorry I could not be of further help ... Regards Vortash
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Tv won,t turn on.
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.6_17_2012_5_32_24_pm.jpg6_17_2012_5_32_48_pm.jpg
Jun 17, 2012 | iLO 3200 32 in. LCD Television
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Can you please tell me what a control code is for a sanyo i have a GE universal remote
Turn the TV on, press the CODE SEARCH or SETUP button until the light comes on, press and release the TV button, the light will blink and remain on, press the POWER button waiting two (2) seconds between times, until TV turns off, it may take 100 tries, once it turns off, press, ENTER or SAVE....hope this was helpful...
Apr 23, 2010 | Universal Remote Control GE174Universal...
I need the codes for my ilo tv i have a universal rca remote
Turn the TV on, press and hold the CODE SEARCH button, press and release TV button,release the CODE SEARCH button, press the on/off POWER button repeatedly until the TV turns off, might take 100 tries, once it turns off, press and release the ENTER button.......hope this was helpful......
Apr 20, 2010 | RCA Universal Remote Control
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Code for the one forall for a sharp tv
You do not need a code...
Heres how to set up your remete..
Turn on the devise you want to set up.
Press the set up key on the control firmly until the red light lites up and stays lit. Now press the key for the devise you are trying to set up(dvd, vcr, tv etc..).. the red light will now turn off.
Now facing the devise, begin pressing the power button several times until the devise turns off. Be careful not to press the power button any more after it turns off. After it turns off , you must immediatly press the enter key in order for the control to save the code. Now your control is set up. If this does not work , it is because you pressed the power button once more after the tv turned off....
This process might take you anywhere from 3 to 5 minutes.
despino1@hotmail.com
Jan 10, 2008 | Sharp 27C-240 27" TV
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Polaroid FLM-323B Television Logo
183 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
