Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Water won't drain from the washer
I reduced the load, and the water still wouldn't drain. After the rinse cycle the machine just shuts down. Any help would be much appreciated
    Scholar:
  • 85 Answers
Most common problem is clogged pump. Unplug and remove back cover. Pump should be at rear left o washer. Clamp off tub-to-pump hose if you can and have plenty of towels handy. Pull off the clamp from the outlet part of pump. Make sure the Back-flow stop flap is not stuck up in pump. check up in pump and remove any obstructions. May have to do same for other opening of pump. If this does not correct the pump may be bad or may have problem in control board.
Posted on May 20, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
My wash machine won't drain
sounds like you got a blocked empeller on drain pump,coin or something,also drain pump could have failed,a sock could be stuck at drain pipe from drum,hope this helps
May 12, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water wont drain
something is stuck in the drain pump axcess through front panel.
Sep 30, 2007 | Kenmore 44102 Front Load Washer
Front Loading Washing Machine - stuck in cycle.
there may be a simple solution. on rinse the water level is higher. it is just possible that the water is syphoning out. try putting the drain hose higher in a swan neck
Apr 05, 2007 | Frigidaire GLTF530DS Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
190 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
