Question about Foxconn P4M9007MB-8RS2H Motherboard
How to conect wires frome SystemHouse to the Motherboard
  • 116 Answers
Here is the manual
Page 18 explains the headers
Posted on Oct 14, 2007
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
Ice tray is full and fill tube continues to run.
Your water valve is bad or the ice maker itself is bad.
Start with the water valve. Im not familer with inglis but this should help. find your water supply line frome the wall to the refrigerator, this should lead you to the water valve. Unplug the machine and then unplug the wires that are conected to the water valve. now you can check to see if the water stoped. (( of course the water has to be turned back on if you shut it off ))
If you still have water coming in then the valve is stuck open and will need to be replaced.
If the water quit coming in the fill tube then the ice maker is bad and will need to be replaced.
Jan 12, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Remove am fm radio frome dash
Oct 30, 2009 | 2000 Chevrolet Tracker
Installation of a JVC cd player
ok if you are going from a factory starieo to this you are going to need an instal kit you can get it from walmart then you are going to have to take off the plastics frome around the cd player after that there are 4 screws that come out un plug it conect hte plug from the instal kit in and wire it to the jve the wires are colered cordenated yellow to yellow thats the memory red hot black ground and then the speeker wires solid to solid stripe to stripe screw it in and put plastics back
Jun 04, 2009 | JVC KD-G230 CD Player
Conecting front panel wiring to INTEL 845GRG MOTHERBOARD.
Normally a small area of 10 pins or 9 one is not used,you nedd the book or go to manufactuers website and download user manual,connect your wire to the board with out a diagram and you could damage the board
Jan 15, 2009 | Intel D845GRG Motherboard
First you must check to see if you have installen the new system properly by checking all your conections..and that they are conected to the proper wires..the instructions provided for you frome the alarm companny will guide close attention when installing your new system as manny of the problems that occur are do to iproper instalation...hope this helps you...
Oct 20, 2008 | 1997 Mitsubishi Mirage
Need to know how to wire it.
Here is a link to where you can download the manual for this motherboard:
Mar 04, 2007 | EliteGroup K7SEM Motherboard
Foxconn P4M9007MB-8RS2H Motherboard Logo
142 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
