Question about Asko D1776 Built-in Dishwasher
Asko D3100 No hot water
I know this is not the same model but the solution may be the same.
I have just had renovatond done to my kitchen and re installed the Dishwasher - professionally plumbed to cold water only etc.
I can not ge a hot wash, Is there a fuse or a reset button that I should be re-setting or something?
Andrew
  • Anonymous Nov 08, 2007
    i also have a asko d3100 and it needed to be electrically reset. my wife saw it done by the repair man but cant remember how.he did it with pushing programme buttons in a specific sequence.I'd like to know the sequence to write it down for future reference thanks.
  • 209 Answers
Check heater element for open circuit electrically, also there are cut outs located in various places all different depending on make ,model etc
these cut outs are not resettable, they just want replacing if faulty
if all above are well and test ok, it could be a broken wire inside the door skin just above the hinge (very common fault on older appliances)
Posted on Oct 15, 2007
The dishwaser takes a very long time to run thruogh is cycles.
on many models, the timer will not move if the water is not up to temp. be sure that you run hot water in the sink until it gets hot before you start the dishwasher.
are your dishes coming out clean and hot? if not, your heating element may be faulty. this is used for drying, but also to maintain water temp. during the cycle. a bad heating element will certainly make the cycle take forever, if it ever gets done. good luck
Nov 02, 2009 | Asko D1716 Built-in Dishwasher
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
New cutlery basket for D3100
Here is a source for your basket click here
Hope this helps.
Please take the time to rate this solution
Jan 31, 2009 | Asko Dishwashers
Asko D1716 won't start
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Model d3121 does not "heat"... when I use it the water don't be hot and the dishes doesn't dry. you can answer in french i'll try to understand ... as you can see i'm not bilingual but...
In my case, the problem was with the control card, located behind the control buttons on the front. The relay driving 120V, 10A to the heaters had one pin dissoldered, probably because of heating. It was dark around the pin. See the picture attached. The top part showd the PCB with the faulty pin marked by a red arrow; the bottom part shows the other side of the PCB with the relay itself.
Remember that this relay/pin drived 1400 W.
I found the electrical drawings here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3121%20%28DW20.1%29%20SS.pdf
Oct 01, 2008 | Asko Dishwashers
Asko d3100
Remove the lower panel at the back of the machine. If there is water on the bottom pan, wipe it up with a towel or so, and the machine schould be like new again ;-)
Good luck
Feb 05, 2008 | Dishwashers
Asko D3100 - Over filling
you press and hold the programme button and start button then press the power button wait until the light come on then release the buttons .press programme button until the pots wash comes on (time fill) pots wash not on is sensor fill.then you press the start button to lock in your choice.You will probably still have to replace the valve complete as it will cause an overfill problem
Dec 22, 2007 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko D1776 Built-in Dishwasher Logo
331 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
