When I transfer a call to the conference room the Polycom isn't ringing. I have to yell to pick it up .
SOURCE: Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station. On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button. Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider. If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
SOURCE: Dropped Conferences
You need to upgrade the code on your system. This happened to me and upgrading the code fixed it. Good luck!
SOURCE: Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
SOURCE: How do I find the MAC Address for my Polycom ViewStation ISDN Video Conference?
I just called Polycom and the guy said it starts with 0003 or 0004. Sure enough I had one of those numbers, it was the same as the serial number on the box the phone came in. This number is found on a sticker on the back side of the phone. Easy to find, but not labeled as a "mac address"
