Question about Dell E173FP 17" LCD Monitor
Wacko Dell E151FPB
I just recieved thisdellmonitor from my brother worked fine for him (yes I seen it work) I pluged it in and cable and got safe mode on screen I hit a key tryed to use mouse nothing. turned it off used another key board restarted and same thing . unpluged monitor and got floating self test. How can I get this thing to work besides buy a new one?????Oh and formost my monitor is E151FPB model
  • PPLePew Feb 05, 2009
    Same here. Computer works fine with other monitor.
  • 101 Answers
That sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Posted on Oct 14, 2007
SOURCE:
Windows won't start with safe mode
Download a new safemode for dell. my safemode wouldn't work too.
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Fax machine isn't able to recieve or send anything
Make sure there is a dial tone on the phone reciever. If there is not check the connections, the cord could be damaged or disconnected. If there is, check the Recieve mode.
If not call Brother support - its free
Mar 31, 2010 | Brother IntelliFAX 2800 Laser Fax
Dell xps 400 keyboard and mouse not working, but the keyboard does work in when in service mode
If it works in service mode, then it is not a hardware problem. Boot Windows in "Safe Mode" using the F5 Key as it is Booting to Windows. That should make it re-discover the KB and Mouse. Make sure the KB and Mouse are pluged into the right ports. Mouse Green and KB Purple
Dec 30, 2009 | Dell Computers & Internet
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My Dell 1535 Studio Touch pad has stopped working and my key board also has been having problems. The key board does not continue to scroll over when I hold down the arrow keys and some of the keys do not...
try to boot in safe mode first. turn on computer then keep tapping on F8 then boot to safe mode. once you booted in safe mode try to open notepad and word check if all keys working. if yes then try system restore it might be some conflict when in normal mode. if keys same problem in safe mode then try last known good configuration if still having the same problem with normal mode then try booting to F8 safe mode with networking. download the latest toucpad drivers and the latest bios for your system. install all downloaded updates then boot back to normal mode after. check if still the same problem. if yes then try to do system restore to the previous state when laptop keys was working fine. if all fails try to re-install the OS. if fails then have your touchpad, keyboard and palmrest replaced. (Note: when troubleshooting make sure you are using an external mouse and keyboard thru USB)
Oct 23, 2009 | Dell Studio 1535 Notebook
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Aug 29, 2009 | Dell OptiPlex GX620 PC Desktop
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
Laptop works fine in safe mode but freezes in normal mode
Okay, easiest first. In Safe Mode, your sound won't work. Safe Mode means only enough drivers to make your PC more than a doorstop get loaded, so that's okay.
Second, if it boots to Safe Mode without difficulty, try running System Restore in System Tools. Go back to some date before when your issue started. That should get you going. Don't worry, your data files will not be affected in System Restore. I hope this helps.
Dec 28, 2008 | Dell Inspiron 2200 Notebook
Dell E173FP 17" LCD Monitor Logo
160 people viewed this question
Clive
Clive
Alun Cox
