Question about Gateway 505GR PC Desktop
Some problems in comp.
Doesn't show images on the screen & the bootable set-up? what is the problem?
    Scholar:
  • 59 Answers
You need to be a bit more specific with the problem.  What images doesn't it show?  What about bootable setup?  What kind of bootable setup?
Posted on Oct 15, 2007
Can't boot,showing "no bootable device,hit any key
Take it to an IT specialist as I suspect the hard drive may be dead.
May 19, 2013 | Computers & Internet
Hi and sorry to have bother you......I have my computer connected to TV monitor.... Before it would show the two screen, the comp and the tv. I went to hit the number lock and i hit the Scr LK button by...
On laptops both the laptop LCD screen and the external video port can be toggled to show laptop LCD, external vodeo and bothe laptop LCD and external video.
You need to press and hold down the Fn key and one of the function keys that has the monitor symbol, repeated pressing this function key will toggle the video outputs.
I cannot advise you which function key works with your laptop as they vary between different laptop manufacturers.
Sep 09, 2011 | Logitech Cordless Desktop EX110
Hi guys i am facing problem while trying to install or even boot from CD or USB, my problem it's when i press any key to boot from CD i just get blank screen and i thing the laptop is stuck. Please...
Ok so I'm guessing it's detecting it's a bootable CD since it is prompting you to "press any key to boot from CD" right? If it goes to a blank screen after that and doesn't go any further, I would think it's 1 of 3 things.
1, the CD you are using is bad or damaged. Try a different bootable CD or try to burn a copy of that one and try with the new copy.
2, Could be a memory issue. If you have multiple sticks of RAM in your computer, try removing 1, testing, then the other (while replacing the first one you removed).
3, Your Hard drive could be corrupt or damaged. I would first try wiping it clean with a program like Darik's boot and nuke (http://www.dban.org/). THIS WILL DESTROY ALL DATA ON THE HARD DRIVE. Then try to re-install again.
Jun 24, 2011 | Computers & Internet
How to set up windows xp to laptop without using cd rom
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
May 08, 2010 | Microsoft Windows XP Home Edition
BIOS settings to boot from pen drive
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
4. BOOT FROM USB
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
Apr 03, 2010 | Computers & Internet
Burned image on comp 1 chanel
When an image is burnt in to screen it is always there you just dont see it when you watch tv because of the changing video. On some sets you can burn the image out by using a all white screen, from a signal generator or from the service menu, turning the brightness all the way up and letting it play for 24 hours. Here are some websites that have software that is supposed to erase burn-in images, but you would have to hook tv to a computer, unless it can be copied to a dvd and played through a DVD player. Have not used it myself so not sure how or if it works. Be careful not to cause any more damage to screen. A new screen can cost a few hundred to over a thousand dollars to replace. Set should be taken to a panasonic repair shop to try burning it out with white screen approach, so if they damage it they have to fix it.
http://www.sharewareplaza.com/JScreenFix-download_44365.html
http://www.top-shareware.net/lcd.html
http://www.fast-download.info/screen-fix.html
Nov 03, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Ds32gt32.dll image error......
DLL ERROR NOT GOOD,HAVE YOUR TRYED DOING A SYSTEM RESTORE ? OR WHEN THE SYSTEM IS FIRST TURNNING ON HIT THE F-9 OR F-2 OR F-11 DEPENDING ON YOUR TYPE OF COMP TO GO INTO YOUR BIOS AND RUN YOUR COMP IN SAFE MODE SO YOU CAN RUN A VIRIS SCAN AND IF ALL ELSE FAILS AND YOU HAVE A RETURN TO FACTORY MODE OPTION OF A DISK THAT CAME WITH YOUR COMP YOU'LL HAVE TO RUN THAT BUT YOU'LL LOOSE ALL YOUR SAVED INFO AND YOUR COMP WILL GO BACK TO FACTORY SETTINGS
Mar 09, 2009 | Microsoft Windows XP Professional
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
No signal
You can check if your monitor can be fixed or not. After you turned it on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | Computers & Internet
Gateway 505GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
