Question about Maytag SAV5710 Top Load Washer
Model GTWN4950LOWS very noisey in spin cycle
My GE washer sounds like a jet plane taking off when in the spin cycle. It is model GTWN4950LOWS Serial # AT116994G
SOURCE:
SOURCE: Neptune washer load noise.
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
Posted on Sep 13, 2008
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
  • 85 Answers
SOURCE: LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Posted on Dec 16, 2008
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
  • 274 Answers
SOURCE: Maytag washer (model PAVT244AWW). Won't spin.
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Posted on Jul 05, 2010
Testimonial: "Response was helpful to figure out our options!"
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
I have a GE Select Top loading wash machine that is making alot of noise during the spin cycle. 99/2000 model
If it sounds like a jet plane taking off, a grinding noise, it is the bearing. This is pretty difficult to replace. If you do attempt it, you MUST replace the inner tub seal. This is leaking onto the bearing, causing it to go bad.
Jan 18, 2010 | GE WBSR3140DW Top Load Washer
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
How to lift the lid on our top loading GE washer
It does just lift up but it is held in place with clips that are forced into openings so you have to use some force to separate the two.
slide a putty knife in the crack and work it around. as you do so it will start to open for you.
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
May 20, 2009 | GE WJSR2070B Top Load Washer
Very Noisy Washer!
Hello julierealtor how old is the washer? Try turning the inner drum by hand and see if it is noisey or moves up and down. If so then it is either your rear support of the inner drum that has failed or the rear bearings. If it seems fine, maybe you have something in the drain pump (which runs prior to and during the spin) that is causing the noise. If it is noisy during the drain, then you may either need to clean out the pump or replace it. Hope this helps.
Aug 10, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Maytag SAV5710 Top Load Washer Logo
112 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
