Question about Dometic Rooftop RV Air Conditioner
E4 error code on climate control center
I have a Dometic Duo-Therm with Climate Control Center. It is showing an E4 Error Code. Any possible solutions?
22yooper
  • 828 Answers
SOURCE: Duo-Therm by Dometic Thermostat
Generally on most thermostats R is the power to the thermostat, W is for heating, Y is for cooling, and G is for fan operation.
Posted on May 31, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
  • 127 Answers
SOURCE: dometic duo-therm air conditioner freezing up
Make sure that you are not running the unit on low fan speed. In the warmer months of the year, this will often cause the unit to freeze up due to the lack of air flow through the evaporator. If you are running on high and it is still freezing, then you possibly have a freon leak in the system. The brisk airs are notorious for the capillary tubes in the upper unit rubbing together and developing a small leak. The problem is usually where the two small tubes enter the evaporator housing. Remove the cover and pull the two small lines apart, damage should be apparent if there is any. If not, you may have developed a leak elsewhere and need to have someone check out the system.
Hope this helps,
Jeff
Posted on Jul 05, 2009
  • 534 Answers
SOURCE: my dometic duo therm brisk air RV a/c unit is not cooling the RV
clicking sound could be thermal overload on the compressor. If the compressor has gone out the unit will not cool the clicking sound is possibly the compressor trying to reset but if the compressor has "gone to ground" (winding burnt out) you will need to have the compressor replaced. Good luck on your repairs hope this helped some
Dave
Posted on Oct 27, 2009
Error code E2
open circuit or out of range indoor temperture sensor. locks out cool and heat.
Aug 09, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo-therm 610015-305 does nothing
check thermostat if ok possible board
May 28, 2010 | Dometic Rooftop RV Air Conditioner
Dometic duo therm a/c for rv
generally most R/v dealers should have those replacement parts they will have detailed diagrams that you can tell them exactly what you need
Aug 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
259 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
