Question about Mitsubishi VS-45609 TV
Tv turns off when it feels like it
Turning the tv on requires constant pressing of the remote on button for 10 min. Tv will then turn off if you change the channel to soon after it's on but will come back on quickly to default station Is there anything I can do same thing happened with my last tv but it finally just refused to come back on after shuting down both a zenith models
    Novelist:
  • 153 Answers
There are 4 possibilities.
1. weak remote batteries
2. failing remote button pad
3. failing infra-red LED in remote
4. failing infra-red receiver in TV.
First, try another fresh set of batteries.
Next, replace the remote, third, have a TV shop look at it.
Posted on May 12, 2009
Need code to program audiosonic universal remote to dick smith tv
Give this a go
1 turn on the tv you want to program to work with the remote control. hold the remote in a straight line in front of your tv at a distance of less than 1 metre.
2 press and hold down the remote device mode button (tv) and the (power) button at the same time until the red light indicator lights constantly.
3 press the power button
4 the (tv) button will blink continuously in red meaning that the remote is searching for the code of your tv.
5 when the remote finds your tv code the tv will turn off.
attention: when the tv turns off you must immediately press the (ok) button to avoid the remote to go to the next code.
6 by pressing the (ok) button you have already stored the code. the (tv) button light will turn off.
Feb 05, 2017 | Universal Televison & Video
I have a problem with my thompson tv i can not turn my tv on or off with my romote or my fingers
Did you try unplugging and replugging the set to reset? Checking remote battery? Actuating each remote function (button by button) twice in succession to reprogram? Also, could you have inadvertently de-programmed by pushing the PROG or similar button? Mfrs not uncommonly but that button in the wrong place where users, especially button mashers, are apt to push them trying to turn of the set. The suggestions above might reprogram. Other wise contact customer service for the TV and let them guide you.
Nov 03, 2014 | Televison & Video
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
Need remote code for an RCA television
I have had several remotes; 1 was RCA. Resetting the remote was the same on all - 1. turn TV on, 2. press and hold code search button until light goes on (some flash, others stay on), then release 3. press TV button, release once light goes on 4. press on button every 10 seconds or until TV turns off - up to 100 times pressing button!! 4. press enter . Now the test... turn TV on - good luck
Jan 02, 2013 | Televison & Video
I have a problem with my sears model c539-14249 television. I must have hit the wrong button on my remote and now the tv feature scroll down on my screen constantly while i try to watch tv. I need to find...
You have turned on the demo mode of your TV. One of there procedures should turn it off for you.
1) Press the Time/Day and Control > buttons on your remote at the same time.
2) If that doesn't work press the Menu button on the front panel of the TV for 10 seconds.
Mar 05, 2011 | Televison & Video
I would like to know how to pro. 103602 ir remote
In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
What button is the address button
What is thecode for rca tv
Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Blinking Stand By/Timer LED
You can try this on the remote in standby mode, meaning tv plugged in but set off. Press Display,5,vol+,power on remote.Press each button within a 1 sec interv. Next the CRT display the item being adjusted. Press 1or4 on remote to select item. 3or6 to change the data. Press Muting then Enter to write into memory. Service Reset muting green enter red. Press 8 then enter on remote to initialize. turn set off to exit. wait least 10 sec. before turning back on.
Sep 10, 2007 | Sony KV-32V40 32" TV
Mitsubishi VS-45609 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
