Question about Garmin StreetPilot c340 GPS Receiver
Unit powers up then abruptly shuts down
The unit will not stay on
Battery is almost dead. I had the same problem. Had to keep charging battery for about 12 hours thru my PC. That solved my problem.
Anil
Posted on May 13, 2009
My Lenovo thinkpad R500 shuts down without warning
Check over temperature. Is the air way clear of dust and fluff? Is the fan and radiator clear of fluff?
Aug 20, 2016 | Lenovo ThinkPad R500 Notebook
After turned on the power, the unit shuts down immidietly
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
Mar 12, 2015 | Onkyo Ht-r510 5.1 Channel 100 Watt Av...
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
2004 Dodge Sprinter abrupt engine shutdown.
need more info does it run warm
Jan 29, 2014 | Cars & Trucks
JVC car audio cd receiver model # KDR-310 will not stay powered up. Shuts down after 2 seconds. What's wrong??
hi marnie, if all the power and speaker cables are connected correctly, then you might have a faulty or shorted speaker in the vehicle.your unit is sensing a fault condition. check the impedance of eack speaker connected to the unit from the harness plug. if this does not help then your unit needs to be bench tested.
May 23, 2012 | JVC AM FM CD DET FACE CAR STEREO
McIntosh C-39 preamplifier will not power on. Over the last several months this problem has gotten progressively worse, from taking several tries with either the remote or physically pressing the power...
Is it plugged in directly to the wall or are you using a Uninterrupted Power Supply or Auto Voltage Regulator?
Check for any signs of overheating on the Capacitors and the IC's usually this intermittent shutdown can be caused by a faulty capacitor which cannot hold the electricity and thus causing the unit to shutdown.
Hope this helps!
Aug 14, 2011 | Audio Players & Recorders
My computer keeps shuting down at any given time
computer abruptly shutting down does not have anything to do with hdd errors unless it tell you there was hard disk error
if computer shuts down in like a second or two, you might have a problem with the power supply unit, or the power cord that goes to the computer is loose in the tower or on the wall socket.
if the computer shuts down normally i.e. windows displaying "windows is shutting down" massage that you would get when you normally shut down pc...then you might wanna check your power plan option from the control panel. disable any hibernation/shut down options.
go to control panel, go to power option, go to edit this power option..
you should see if you have selected to shut down the computer after a given time...select this to never and it may solve the problem.
Nov 05, 2009 | Computers & Internet
Compputer shuts down abruptly
If you have recently fitted new hardware. Take it out.
If not, buy a power surge protector from your local pc store
Jan 30, 2009 | 2005 Mercury Villager
It sounds that you might having problem with your power supply unit, try replacing it with another working one. Problems like this one can be caused by defective power supply unit.
Nov 10, 2008 | Dell Dimension 2400 PC Desktop
Garmin StreetPilot c340 GPS Receiver Logo
196 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
