Question about Fellowes S701CM Shredder
Overly loud shredding; stops prematurely
I think my Fellowes S701CM Shredder is permanently damaged. It is much louder than usual when shredding paper, and when feeding in the second set of paper sheets (3 at a time), the motor slows and stops completely. Is there a repair solution or can you suggest a recycling place?
  • 328 Answers
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on May 15, 2009
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
How doyou remove the top to a fellowes s701cm shredder
Remove the six obvious screw around the perimeter of the underside, plus one more screw in the center that's hidden under a label. Then cover will just lift off.
Feb 02, 2012 | Fellowes S701CM Shredder
It makes a loud screeching sound, i think it needs to be lubricated. how do i lubricate it?
Sqirt shredder oil on a piece of paper that you want to shred & feed it through your shredder. Do not soak the paper a little is all you need.
Jan 12, 2011 | Fellowes Powershred C-320C Shredder
Paper is passing through shredder without being shredded
Damaged bearings on the cutter shafts have allowed gaps between cutter shafts to prevent proper shredding, I think.
Apr 30, 2010 | Fellowes SB95C Cross-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Exploding paper shredder - very dangerous
I'd call your lawyer and tell him you can't touch any machinery which contains an electric motor because you have been psychologically damaged. Maybe Fellows will settle out of court.
Otherwise ring your local 7:30 current affairs news program.
I don't know why their motor would not be shielded from paper dust.
It is no big surprise that it may be dusty in there.
I'm glad you did suffer any permanent physical damage.
Oct 05, 2009 | Fellowes DM15C Shredder
Fellowes S701CM Shredder.
You can check the switch out by spraying some WD-40 in it, that clean the contact in side the switch
Mar 09, 2009 | Fellowes S701CM Shredder
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Fellowes S701CM Shredder Logo
390 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
