I have lost the admin password for this router and I need to make some changes. Is there a hardware reset or is there a built in security user Via the CLI interface who I can login as to make changes.
Flashing the firmware clears the password and all other settings.
1) Download the firmware (and manuals) from
http://ftp.dlink.ru/pub/FireWall/DFL-500/Firmware/
2) Install a TFTP server on your PC - I downloaded Tftpd32, another one is TinyTFTP by Solarwinds.net
3) to save time, unzip the firmware to the TFTP server's directory and rename it to image.out
4) connect the DFL-500 to your PC using a null modem cable and use any terminal program (HyperTerminal in Windows, Minicom in Linux, settings 9600-N-8-1)
5) connect the DFL-500 either to your LAN router (straight cable) or your PC (crossover cable)
6) boot the DFL-500 by plugging in the cord
7) you have three seconds at the "Press any key..." prompt to hit a key
8) when prompted, type your PC's IP and make one up for the DFL-500 (according to the directions, you should change your PC's IP to 192.168.1.2 and use 192.168.1.99 for the DFL-500)
Here are some sample boot messages:
FGT-50(11.04.2002)
Ver:02080001
SerialNum:FGT-XXXXXXXXXXXX
SDRAM Initialization
Scanning PCI Bus...Done.
Total RAM: 63M
Enabling Cache...Done.
Allocating PCI Resources...Done.
Zeroing IRQ Settings...Done.
Checking IRQ Routing Tables...Done.
Enabling Interrupts...Done.
Boot Up, Boot Device Capacity=30MB.
Press Any Key To Download Boot Image.
Enter tftp server address [192.168.1.168]: 192.168.0.24
Enter local address [192.168.1.188]: 192.168.0.254
Enter File Name [image.out]:
MAC:00:05:XX:XX:XX:XX 100Mbps full-duplex
Total 7678257 Bytes Data Is Downloaded.
Verifying The CF Image.
Total 29500kB Are Unzipped.
Do You Want To Save The Image ?[Y/n]
Programming The Boot Device Now.
Reading Boot Image 918457 Bytes.
Initializing Firewall ...
DLINK-500 login: admin
Password:
Welcome!
Type ? for a list of commands.
Please rate this solution if you feel it has helped you! Thanks, and good luck!
we want to access one site how to possible Please tell me command for operate my firewall router...
(More)
we want to access one site how to possible Please tell me command for operate my firewall router TIPS AND COMMAND .THANKS
actually, my firewall system is block some one side ,but i want to access one site , we want to...
(More)
actually, my firewall system is block some one side ,but i want to access one site , we want to configuration for access this site.thank.
