Question about Cingular Wireless Cingular 8525 Smartphone
Phone doesn't ring & won't record or play back messages
I tried a soft reset and changing the ring tone, neither fixed the problem. I'm reluctant to do a hard reset because I have complicated software installed that requires re-calibration if I re-load it. Any other possible test or solution will be greatly appreciated.
Not sure what solved the problem, but I went through all the windows sounds, testing each one to see if it played. After doing that, the ring tone was restored and everything back to normal. I hope this can work for someone else with the same problem.
Posted on May 13, 2009
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
My lg neon does not play my full message tone what do i do
hello,since you said it does not play your full message tone,all i will advice you to do is to see if the message tone you chose to ring truly was fully recorded,if not i will advice you download or record another one that will suit your taste.thanks,you are appreciated.
Mar 09, 2010 | LG Neon GT365 Cell Phone
Ringar is not working plis help
ok first you need to check to see if your phone plays any tones at all .
if so you most likely have your ringer turned off. go to menu then settings then sounds. in sounds select ring tone or ring volume.
you will need to check in this area of your phone. select a tone and check to see if your ringer is off.
if that is not the problem you may want to try a soft reset. this will reset your phone to factory settings.
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 14, 2009 | Nokia 3220
My Black Jack II ring tone files are corrupted and will not play
check out this thread. near the bottom is an explanation to reset your phone back to default settings. you will lose all programs d/l so I suggest you sync your phone with your comp to save all your contacts first.
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=68502
Mar 07, 2009 | Samsung Blackjack SGH-I607 Smartphone
Brother MFC 885 CW answering service malfunction
It was all a matter of pressing down the Digital TAD button down hard enough... o-:
Sep 01, 2008 | Lands Phones
Message tone
settings-ring styles-loud detail/soft detail/vibe detail-inbox then scroll down and find a ringtone. while in "loud detail" scroll down and make sure the Ringer IDs are ON. now you can personalize every callers ringtone and message tone.
you cant use recorded files as ringtones. they dont give you the option so that you are forced to pay for them but try this website www.myxer.com you can make your own ringtones then send them to you phone via. your home computer.
Aug 07, 2008 | Motorola Mobility SLVR L7 Cellular Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Cingular Wireless Cingular 8525 Smartphone Logo
96 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
