Question about Apex Digital GB55HD09W 55" Rear Projection Television
Apex out of convergence
I have an Apex GB55HD09W. I am getting triple images and I know that the convergence is out of adjustment. I followed the directions in my operation manual, and the tv is not responding when I push the appropriate keys to adjust it. I can get into the menu, and get to the adujustment screen, but then, no response. What does this mean?
    Problem Solver:
  • 12 Answers
I have this TV and have fixed this issue. If you cannot adjust Red or Blue convergence, then your STK ICs are defective. The signal board or Digital convergence board is not able to adjust sig lines on the deflection board so pushing buttons does nothing. The STK's are your amplifiers for vertical and horizontal. This will require dissassembly and soldering. You'll need 2 STK392-020 IC's and 125v/5A pico fuse or buss fuse..
The STK's are mounted on 2 massive heatsinks. Can't miss it. Word of advice, LABEL the 3-4 Pin plugs B,G,R from left to right. These are your Vertical and Horizontal coils for each tube. Don't mix them up. I did and the tv survived luckily. Chances are if your STK's poped, then they took out the -25v line. Take out the power supply that is mounted vertically on the right. Look for a row of axiel lead fuses with "SOC 5000" printed on it. They look like white rectangular blocks with leads. Check them all. Particularly RF817. Sits next to RF814. The service manual lists it as a fuse and NOT a Resistor-Fuse like the label suggests. I found more than one typo like this. I replaced mine with a generic 125v/5A fast blow buss fuse. Soldered in a holder for it. Should work the same.
Took me abit to realize it was a fuse on the power supply. This -25 line traces to W057/W058 next to the first STK chip. Explains the symptoms.
Posted on Dec 05, 2009
Double images. convergence problem.
stewearserra,
You are correct, you have convergence problems. But I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will answer all your problems as well as tell you how to complete the repair and where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 13, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
Blurred picture red and blue shadows
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are dis aligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to refer to the manual on how to go about it
Nov 29, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
Access Convergence Menu APEX GB55HD09W
did you ever find out why you couldnt get into convergence?
Feb 16, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
Apex gb55hd09w
you need two STK392-020 - 3-Channel Convergence Correction Circuits. they run anywhere from $10 to 40, then either you or electronics shop solder them in
Oct 18, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Service manual to fix color convergence
I would like a service manual for this tv as well if anybody has one. However i did call apex and they said there is no service manual for this tv
Jul 01, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Convergence
Your set needs two convergence ICs they are STK392-020 you can get replacements at the following link and they procide free instalation instructions with pictures so you can do the job yourself which takes about 40 minutes from beginning to end. Heres the link.
http://servicemanuals.vstore.ca/
May 14, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Convergence issue
Replace both convergence ICs number STK392-020 you can get replacements at the following link and they provide free instructions woth pictures so you can do the repair yourself.
Apex gb55hd09w triple vision
Go in and find the conv ICs, they will be mounted on a
big heatsink and the wires going to the conv yokes will
most likely plug in somewhere closeby.
Conv ICs are the workhorse of the CRT RPTV, and it is
not unusual at all for them to need to be changed out
at some time in the life of a CRT RPTV.
Mr Bob
Comment by MrBob84, posted on Feb 04, 2008
PS -
The wires for the conv yokes at the CRT necks are the
thin ones. The thicker ones are for the hor and vert
sweeps, which must never be disconnected from their
circuitry during CRT operation.
If your beam loses sweep on any of the CRTs, it will
instantly score/gouge your phosphors on your CRT faces,
vaporizing the phosphors there and ruining the CRTs.
The beam is very powerful, but in normal operation
moves incredibly fast, not damaging anything. Any
slowdown of the movement of the very powerful beam that
draws the picture, acts like the searing vaporizing beam in Tom Cruise's War of the Worlds.
Feb 04, 2008 | Televison & Video
Convergance green image is to far to the right and goes into a double image
If you know how to solder and unsolder and understand the circuitry of a tv set, then those are the IC's you will most likly need to change. I would look at the fusable links on the board also. If you dont have the training for TV's, this is not the place to begin experimenting with. good Luck
Aug 11, 2006 | Apex Digital GB55HD09W 55" Rear Projection...
Apex Digital GB55HD09W 55" Rear Projection Television Logo
459 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
