Question about Brother IntelliFax-2820 Laser Fax
Copy and fax problem
When i fax or copy somthing it comes out with 2 lines on it , whats the problem?
  • 469 Answers
Open the document feed portion of the machine, this should expose the exposure glass. Clean this glass with a good quality glass cleaner and soft paper towel. But sure to check closelt for any spots or streaks.
Hope this is of some help.
Ed
Posted on May 12, 2009
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
When sending a fax, black lines runs thru entire fax, what to do?
Clean off the glass where the paper runs through.You have some dirt or other substance that is blocking the light for copying or faxing.
Apr 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax machine sending but not receiving --help me!!
Check the settings and see if it went into "memory" mode. They may call it somthing else in the menu so check the manual if you have it.
Mar 23, 2009 | HP 1040 Plain Paper Inkjet Fax
Straight line comes up when i make a copy or fax to some one
if your received faxes look good and this only happens when you fax someone or make a copy, lift up your document feeder and you will see a glass under it that is about an 1.5" wid and runs left to right. something is on that glass. perhaps whiteout or something like that. clean that off good and you should be fine. if it doesn't take care of problem, write back.
Feb 11, 2009 | Brother IntelliFAX 2800 Laser Fax
Multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Jul 09, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Stop the Samsung CLX 316FN from answering the house chat line
Make sure that the unit is hooked to the fax line only. Many people often merge both lines when connecting answering machines and more than one wireless phone. Also make sure that the unit is the FIRST equipment connected from the wall outlet. Finally, enter the program mode and make sure the fax setting is turned to FAX or TEL. The first setting makes the unit answer after the amount of rings programmed, while the other setting is for manual reception only. One final notice: if you are using the phone line for talking and someone hits START for a copy, the unit will assume a fax and iterrupt the communication. To avoid this, press NO. COPIES first before making copies. Even if it is for one copy only.
Oct 04, 2007 | Samsung CLX 3160fn All-In-One Printer
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
50 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
