Hello, can anyone advise please ? pug 307 1.6 PETROL 05 plate rad fan comes on intermittently and after turning car off. not overheating a changed temp transmitter in stat housing. Any advise helpful
I'm pretty sure the radiator fan on these is controlled by a thermostat and will therefore normally operate only when required hence coming on and turning off at will. It is also not unusual for the fan to remain on after turning the engine off. If you sit and wait a few minutes after turning off the engine the fan will shut down eventually.
SOURCE: 2002 peugeot 307 wont start
Sounds like a starter motor problem. Possibly a sticky solenoid. Try rocking the car or giving the starter and solenoid a hard bang with a hammer.
SOURCE: 307 fuel fault blocked filter and pollution fault on dash HELP
Try disconnecting your battery , this should reboot it and remove the code .
SOURCE: WHISTLING BELOW TURBO
Its surely not turbo, its is somewhere a hole or leak in turbo air filter housing or air inlet pipe that is making noises when turbo sucks air. check the air pipes wheather they are fitted correctly. Take a keen look at air hose and close any hole with silver tape check the hose is fitted correctly in Turbo air filter housing (if not then it makes whistling noise when air is being sucked by turbo) . Clean all air filters and then give it a go.
SOURCE: Peugeot 206 temperature gauge not working?
it could be a couple of things, first, check the wires to the temprature sender unit make sure they have not broke, as it was sudden this may be it, also it could be the sender unit it self as a freind of mine had with her car i changed that and the one for the radiator switch, but most of the time it will be something to do with the sender unit on the engine...hope this helps
SOURCE: Peugeot 307 A/C blowing hot air
Some garages are offering free diagnostics on AC systems. I'd try one if it's free.
They will then try and sell you a "service" - which is just refilling your system with a can of refrigerant.
Don't let them do this - It'a DIY job - cans available at most car factors.
