Question about Whirlpool Washing Machines
Drain error code f21
My whirlpool washer has an f21 error. We have taken the front off and declogged, but we are still getting the f21 error.
  • ucbirthmama May 12, 2009
    I removed the front panel and checked where the white tube is where you can screw off cover. I have declogged some grimy hair/ water. We have had stuff come out of there before, sponges etc. Nothing like that today. I then removed the pump turning clockwise and discovered nothing dicernable, found nothing but grime, greyish. Now when I turn washer to drain it makes a sucking sound just past pump where waer drains upward into tube to e removed by hose attached to back. Prior to removing pump access it was not making that sond at all. Pump is warm, makes sounds. Not sure if it is the pump or?
    The housing you speak of I do not know where that is located? On the pump itself? Thank you
  • ema31
    ema31 Aug 11, 2012
    I also decloged my washer from the front ploge but now the hot water won't stop filling into tank I need to shut of water so it can stop feeding into washer. Can someone help me fix this
  • 82 Answers
Hi, you say you have de-clogged it? But where? There is a water trap / housing that fills with water and forces air up a tube to close the contacts on an electrical switch. Have you found this housing and confirmed it's clear? With the water drained and F21 showing, pull the tube carefully off the 'air switch' Do not electrocute yourself but listen for a click. If you hear one, the housing is not letting the water drain quickly enough. If there is no air in the tube, maybe the switch is sticking? Disconnect it and see what happens. Let me know and leave feedback if i have helped. Regards jb
Posted on May 12, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool washer is not finishing the cycle and gives an error code of F21 at the end of the cycle can you tell me what this is? tks Phil
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
595 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
