Question about Sony DSR-1800 DV/Mini DV VCR
Error 91-1D5 while recording - Sony DSR-1800 DV/Mini DV VCR
  • 4 Answers
Posted on Aug 08, 2009
  • 53 Answers
Error 91-1D5 while recording it means Communication error between system control and the DV microprocessor.there 4 main fuse in DV board check them.F1 to F4
Posted on Mar 25, 2011
DSR-1800AP error 36-000
Posted on Dec 15, 2009
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
When printing a label on brother QL-1050 printer comes up with error "Either BOF or EOF is true or the current record has been deleted Requested operation requires a current record" I have removed...
I solved this problem by pressing "Control N" to bring up a new label. Works fine that way.
This is the answer Brother gave when I called them:
Description of Problem 100000003722
When I click print I receive the error message: Either BOF or EOF is true, or the current record has been deleted.
Description of Solution 200000004488
This error message occurs when you print a label that has no record in the database table.
To avoid this error message, click on Database menu, select Create New Record.
Oct 09, 2010 | Brother QL-1050 Label Printer
Digta 410 fat error
Try formatting the memory - or try using an external memory card (SD).
May 28, 2010 | Grundig Digta 410I Digital Recorder (32 MB...
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Cant record video-- keep getting error code
Never mind--- Just needed to restart the computer-- works fine now!
Sep 29, 2008 | Logitech Quickcam Chat Webcam
Magnavox error code
i get the same error code just putting in a dvd and hitting the record button
Aug 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sony DSR-1800 DV/Mini DV VCR Logo
539 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
