Question about Whirlpool 24 in. DU940QWD Built-in Dishwasher
E1 Error on LG Dishwasher (LD-2040WH)
Hi All
We are having a problem with our LG Dishwasher. The machine is washing for about half an hour and then will stop and report an E1 error. According to the user manual this means "Water leakage in Hose connection" or "Water is leaked by damages". We have checked the diswasher's water connections and can't see any water leaking out. We have also cleaned the filers and checked the spray arms but that has not made any diffrence. Any suggestions what this error means and what we can try to resolve it would be appreciated.
  • 4 more comments
  • mkm1047 May 04, 2008
    I'm having the same problem and would appreciate any advice. My guess is I should just buy a cheapter tried and true Whirlpool or GE.
  • agbotha Jul 28, 2008
    I have the same dishwasher modem and after full investigation for water leaks etc. could not find anything wrong. Sometimes by selecting the shortest washing period all seems fine, but when selecting it again it comes up with the E1 code haldway through the cycle.
  • Anonymous Sep 22, 2008
    Is t difficult replacing the Drain Pump in the LD 2040WH?
  • bams78 Apr 18, 2009
    i have the same problem help my
  • folscher Apr 25, 2009
    jwdoyle's "E1 Error on LG Dishwasher (LD-2040WH)
  • Jeff Meyer May 11, 2010
    Is anyone who posted to this message still having problems? There are some excellent solutions to the E1 error. Please post back if you are still having problems.
    Please provide you LG model number when you post.
    Thanks!
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Posted on Aug 13, 2008
2 Suggested Answers
SOURCE:
  • 106 Answers
SOURCE: E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Posted on Mar 30, 2010
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
Kind Regards
JEDEMEYER1
Jul 21, 2011 | LG Dishwashers
I have a freestanding LG dishwasher and the E1 error message has come up. How do I fix it?
The E1 ERROR mean's your main wash motor is clogged or failed & you need to pull it apart completley to test or clear the blockage.Generally its just clogged so get a lg service guy to do it cause he will know your dishwasher inside out.THANKS, ECO KIZZA
Feb 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Have E1 problem,machine stopped running,replaced washerpump/motor,runs for a few minutes E1 comes up and machine stops,any ideas
I had the same problem, new wash pump didn't solve the e1 error. New capacitor did the trick. Hope this helps
Jan 25, 2011 | LG 24 in. LD-12BW5 Free-standing...
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Nov 28, 2009 | LG Dishwashers
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Aug 30, 2009 | LG Dishwashers
E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
2,867 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
