Dvd tray will not open
My sony dvd player drawer will not open. everything else seems ok. the tray isn't locked.
  • 150 Answers
If you press the open key and it say open on the display then yu have a cut belt / blowm loading motor or power preoblem insdie the set. If it does not say open/close on the display then you could have a faultt button or processor.
Posted on May 12, 2009
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
Locked Tray DVP-SR320 Sony DVD Player
see this causes and fix it. God bless you
Possible causes:
  1. Worn, stretched, oily, flabby, belt.
  2. Dirty mechanism or gummed up lubrication.
  3. Stripped gear or other mechanical damage.
  4. Defective motor or bad connections to motor.
  5. Bad drawer/eject button.
  6. Missing/bad voltages from power supply.
  7. Defective microcontroller or other logic.
  8. Dealer antitheft lock enabled.
Oct 15, 2012 | Televison & Video
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Can't open dvd drawer
try putting a Blunt knife into the top of the dvd drawer, or where you can get a knife in.
And gently prise the drawer open whilst pressing eject on the Player.
Failing this, you will have to *****disconnect from the mains***** remove the screws on the rear of the casing, remove the top cover, and take out the DVD Disk.
Replace then plug back in, to check if the player is Ok.
**** Only remove the casing if you feel competant**** And if the player has no guarantee Or Warranty****
Mike @ Compurepair.
Jun 12, 2009 | Samsung DVD-P241 DVD Player
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. martindean71@googlemail.com
Jan 21, 2009 | Televison & Video
Dvd tray won't open
unplug the power to reset it.
Jul 07, 2008 | Televison & Video
Toshiba sd-3990 Disc-drawer won't open
I was given one of these the other day. I was told the drawer wouldn't open yet the machine seemed to function fine. I removed the six screws holding the top on the box and then removed the four screws holding the drawer assembly in place. As you lift the drawer assembly out of the box, make sure you release the two pieces of black retaining tape holding the data cable to the box floor. Turn the drawer over and you will see that there is a little sideways bar mounted on the front underside of the drawer assembly. This is sticking. As you press the OPEN button, jiggle this bar and the drawer will open. You may have to manually move the drawer cogwheel a little to help free it up. Hope this helps.
May 22, 2008 | Toshiba SD-3990 DVD Player
DVD S540-needs password and screen scrolls
Open Disc Drawer
Press 99990
Close Disc Drawer
or
Open Disc Drawer
Press 99990 and then press enter/ok button (!)
Tray was closed independently by itself
and that's it. Enjoy!
Feb 19, 2008 | Yamaha DVD-S540 DVD Player
DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Aug 28, 2007 | Sony DVP-NS305 DVD Player
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
Electro Med Services...
