Sony tv problem
My sony wega keeps turning off then on, like every 5 seconds
model kdfe55a20
  • Barbgregwind May 25, 2009
    the screen goes black for a few seconds then comes back on, it does this often at irregular intervals even when watching a DVD
3 Suggested Answers
SOURCE: tv goes black every 5 minutes or os sony wega
If tv goes black and you still have the sound you have a bad lamp.
Posted on Sep 08, 2009
SOURCE: Sony LCD Projection TV turning OFF.....help!!!
lamp light blinking on sony rear projection t.v.
Posted on Aug 02, 2010
42 projection sony wega tv model kdf46e2000 turn on but red lite flash for 3-4 second then tv gose off
Your TV set has entered a protection mode, the system detects a failure. Try to unplug your set for 5 minutes to reset the system...
Sep 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony LCD Projection M#KDFE55A20 keep going black for about one minute and then coming back on. Its happening about every 5 min
Your lamp is probly bad . It is an odd way for it to fail but happens alot on your model.
SONY P/N xl-2200
The instruction manual has instuctions for replacing the lamp.
Oct 20, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv goes black every 5 minutes or os sony wega
Sep 08, 2009 | Sony Televison & Video
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    No Picture but sound
    Your lamp has probably failed. It is a Sony XL2200 lamp
    Oct 06, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
    Update this and we'll hopefully fix the both of them.
    Dan
    Apr 09, 2008 | Televison & Video
    Where is the thermal fuse located and how can I replace it on a Sony Grand Wega model KDFE55A20?
    It's actually pretty simple to replace.
    Go to
    http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70
    and request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
    No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
    Mar 27, 2008 | Televison & Video
    Televison & Video Logo
    121 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
