Question about Garden
Not sure how 2 put strimmer line in so it self feeds
Would like 2 no how 2 put strimmer line in my ryobi plt 2543y so when you knock it down the line will come out
SOURCE: Ryobi petrol 30cc Trimmer plt 3043 ye
Hi! With the red know in one hand, push the spool down with th other to the female threaded shaft comes to the top. Then, hold the red know in the other hand with your index finger on the bolt in the middle, holding it down. Now start threading it onto the female shaft COUNTERCLOCKWISE! Once you get it, it get's easier. Good Luck!~Frank~
Posted on Jun 16, 2008
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
SOURCE: cannot start ryobi 3043 yw grass edger
Check the spark plug and sheck the gap on it then check the wire
Posted on Oct 19, 2008
SOURCE: Ryobi Whipper Snipper plt 3043YE. change clutch plates
Waiting for some information, current had no reply.
Ryoby sent me a line diagram, would be gratefull for further information please.
Cheers
Justin
Posted on May 19, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Where can i get a piston ring for ryobi strimmer,its a 25cc,model number PLT 2543.
Some of these small engines have very limited parts availability so that part may not be available. Try www.jackssmallengine.com
Oct 27, 2016 | Ryobi Garden
Ryobi plt-2543y engine runs okay but head will not
Ken it sounds like the shaft isn't going in to the spigot on the engine. Make sure that the head is on properly and that the shaft is in the spigot itself. If there has been any movement with the head creeping down slightly the shaft will no longer go into it. Try and straighten the shaft slightly to give a couple of millimeters more to the shaft.
Sep 24, 2013 | Ryobi Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Ryobi strimmer
i can not take the cover off to put the line back in
Jun 02, 2010 | Homelite Mighty Lite Lawn Trimmer
My Ryobi PLT 2543 strimmer will run, but cuts out when the throttle is opened
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
Aug 29, 2009 | Ryobi Garden
Cheers
Justin
May 13, 2009 | Ryobi Garden
Strimmer Line
Oct 04, 2008 | Garden
Garden Logo
220 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
