Question about Foxconn P4M9007MB-8RS2H Motherboard
PC wont boot up unless i press reset button!!!
I hope some one can help me - i have a foxxonn P4M9007MB motherboard which i installed after my GigaByte board started giving me issues. Now everything is wroking fine - the only thing is that on initial boot up the pc freezes at the foxconn splash screen, and doesnt boot into windows unless i press the reboot/reset button on front of pc case.
once this button is pressed the computer starts up again, the foxconn splash screen apears then windows boots up without any issues and the pc runs with no problems whatsoever.
What could be causing the pc to hang the first time it is turned on? any help would be great - its driving me nuts!!
thanks for your time.
maxi
  • 20 Answers
Have you reflashed the BIOS
Posted on May 12, 2009
How to factory reset toshiba notebook a45s250, the laptop wont reboot to windows after install in partition d, partition c is still installed but it wont boot in either one of them
Cordoba, Try holding the Zero button down and press the power button once,continue/ still hold Zero button till computer starts.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Factory reset almost ANY Toshiba laptop
Toshiba Satellite A45 S250 Manual
FAQ How do reset my computer back to factory default state System Recovery...
Jul 29, 2016 | Toshiba Computers & Internet
How to reset motherboard for my acer aspire x5400 pc
Usually on motherboards if you :-
1. disconnect it from the power supply
2. hold the power on button in for 10 seconds
3. remove the battery on the motherboard for about 5 mins then replace
when you re boot your motherboard will be reset back to default settings.
You will have to press delete or F1 as you re boot so you can enter the bios to reset the time. then select default settings press F10, save and enter.
as it reboots this time press F8 to enter the windows boot menu select repair my PC from here you should be able to use system repair to roll windows back to a previous configuration.
Any problems feel free to get back to me & I'll help all I can
Apr 02, 2012 | Acer Aspire Computers & Internet
It wont come on. it wont turn on
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for fifteen seconds.
Install either the battery and A/C adapter .Now just press the power button to attempt a boot into the OS.
Contract for further instructions.
Hope this helps.
Oct 07, 2011 | HP Pavilion dv1000 Notebook
Hi there, I've got a Foxconn 45cmx mb, A intel Pentium 3.0GHz cpu, 2g ram. I've search for two days now and although I found a lot of similar problems, none is the same. My pc is working fine, I can reset...
Hi, try to replace the cmos battery:
So the bios can remember its settings.
The battery is a watch type 2032.
Once you have installed a new batttery
enter the bios and set the boot sequence
for the harddrive as first boot device
and the cd/dvd as second.
You can download a manual from here:
http://www.foxconnsupport.com/download.aspx?models=&category=C000000001&Series=&keywords=45CMX&sort=
Hope this will help you.
Mar 31, 2011 | Foxconn 45CMX socket LGA775 motherboard...
How do I, restet the motherbroad on my acer laptop aspire 5100
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Feb 27, 2011 | Acer Aspire 5100 Notebook
When i put it on, it gives the message operating system not found,
Try this. Turn on the computer. While booting, enter the bios setup and check if your hard drive is detected by the motherboard. If not, turn off the computer and refresh the connections of the cable from hard drive to Motherboard (both ends) and power plug on the hard drive. Then turn on the computer again and check if the hard drive is detected. If detected, check the boot device priority. The OS hard drive should be on the first boot. Save your settings (press f10) and enter. Hope this helps.
Oct 12, 2009 | Foxconn P4M9007MB-8RS2H Motherboard
P4vmm2 wont boot up
Disconnect power cord, remove the button cell battery, press the power button to dissipate any stray volts, replace button cell, plug in cord and re-boot, this will reset bios to default settings.
You will get a check sum error so enter bios to re-set date time and other settings.
May 13, 2008 | EliteGroup P4VMM2 Motherboard
Rebbot to factory settings
Hi bgreenejr,
Are you referring to the BIOS or OS?
If you’re referring to the BIOS settings, you can do this by accessing it and selecting "set to factory default" from the menu. The most common way to access it is by pressing the DEL button upon boot up; there are however, a lot of branded PC and laptops may use a different button like F2 or F12, etc; if you’re BIOS is locked, of course you’ll need the password to log-in.
Another and common method of resetting it to factory default is by shorting the CMOS reset jumper located in your motherboard, usually it’s the closest jumper to the battery or the CMOS chip. This does not require any password, actually this is the method used if you forget your BIOS password. I would suggest that you consult your motherboard or computer’s documentation on how to locate the CMOS reset jumper on it.
If you are referring you your operating system, the only sure way to reset it to default settings is if you do a clean install, that means re-formatting your pc and re-doing everything again, kinda messy, unless you can do a system restore that would revert it back to the original date and time when you first install the system, . Hope this helps
Cheers and best regards,
May 06, 2008 | Computers & Internet
My PC Wont Boot Up???
Dear Waqar Khurshid,
What model is your PC and you should do right now is to insert a Bootable CD and troubleshoot the sysem
Jan 04, 2008 | Mercury P4VM800M7 Motherboard
Foxconn P4M9007MB-8RS2H Motherboard Logo
694 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
