Washing machine function dial stops every 10 seconds
When i put the machine on to any wash function it stops after about ten seconds . i have to keep turning the dial slightly to getit to finish but then when it does stop the clothes are still soaking wet , what can i do ? .... dial is not working. i have to manually dial. is there a fix to this?
    Problem Solver:
  • 16 Answers
Timer you have to replace
Posted on May 13, 2009
Programmer stops at no 2
I would get a quote off the washing machine repair person as the fault could be any where in the system eric
Jan 14, 2018 | Washing Machines
Failed to finish wash, managed to get it to drain slightly but drum wont turn when spin applied
Not sure if this will work on your machine but try turningthe water supply off for the machine then starting cycle again, if you do not want to do that you will have to keep setting it to spin unril it works. Please note that this second method may need to be done several times before the machine is emptied.
Jan 13, 2016 | Washing Machines
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
Our frigidaire front loading washer keeps pausing in cycle and it isn't finishing its final spin. If you have any suggestions I would be greatful.
Same for us,,,
We have to turn the dial and try to put it back approximately at the same place on the dial
(turning clokwise 360 degrees)
Sorry this is the best solution I could find
Jun 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have had my Creda 1000 Supaspeed- Economy Plus for about ten years. Just one week ago the program panel stopped advancing at the end of first rinse with all the water still in it. I turned it off and...
Crea8tivefeng,
I wish I could be of some help but the same thing just happened to me! I have also had this washing combo for almost ten years. I haven't yet tried looking at it as it just broke. I can be handy but I have never looked at a washing machine before. With out looking at it I wonder if it could be a belt not letting the spin cycle work. Maybe the dial is broken? If you have found a solution to the problem I would love to hear back from you.
Derek
Oct 07, 2009 | Creda W100FW Front Load Washer
I HAVE A KENMORE WASHER THAT I BOUGHT BRAND NEW IN 2002. AFTER IT FINISHES ITS INITIAL WASH, IT DOESN'T DRAIN LIKE IT SUPPOSE TO, AND CONTINUES THROUGH THE REST OF THE (ENTIRE)CYCLE, UNTIL IT REACHES...
Change the main controll, the one behind the dial that you turn. About 75.00. bucks. Clean hose from lint build up at pump exit inside washer.
May 12, 2009 | Washing Machines
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
Apr 11, 2009 | Washing Machines
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
