Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Tray 2 Printing
I have hp officejet pro l7780 with two paper trays. How do I get tray two to auto feed when tray one runs out of paper?
  • HP Master
  • 419 Answers
Couple of things for you to check out.
1. Is that you've enabled the second tray for the printer. This is normally automatic but to check go to:
START > Printers > L7780 > Properties
- Click the "Device Settings" tab
... then sort out the different setting so they are all correct such as paper size and of course "Tray 2: Installed"
2. The other more common issue is simply that the printer isn't sitting properly on top of Tray 2 and as a result it's not engaging the cog wheel properly to pick up paper.
This is one of those trial and error things where you pick up the printer and re-slot it down onto Tray 2 until it works properly.
Hope that helps...
Posted on May 12, 2009
Where is the manual feed
I think, there is None.
You have only tray 1 so manual feed must also be done using tray 1 by taking out all the other papers
If that is too inconvenient, get the optional tray 2. Fill that with paper and leave tray 1 for manual feed
Nov 02, 2013 | HP Officejet Pro 8600
Officejet Pro L7780 will not feed paper from bottom bin. Tries twice then defaults to top bin
Check that the paper path is clear.
Check that the paper is dry.
Check that the paper pick ups and rollers are clear of any debris - Power off the machine at the mains and brush them with a damp cloth or brush and maybe vacuum out the entire area to remove all dust etc.
Make sure that you fan out the paper before inserting it into the tray and that the tray is not over full as this will prevent the paper being collected successfully. Try running with half a tray full instead of a full or near empty tray.
This should resolve your problem.
Sep 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How do I place the envelope in the printer to print enveloes for hp officejet pro?
Step one: Load the envelopes NOTE: The exact steps for loading envelopes in the product might vary by product model. Please see the User Guide or the product manual for specific information about your product.
  1. Remove any paper from the input and output trays.
  2. Extend the paper tray, and then slide the paper-width guides to their outermost positions.
  3. Place several envelopes in the tray, and then slide the paper-width guides toward the stack of envelopes. Make sure that the paper-width guides touch the edges of the stack of envelopes without bending them.
  4. Slide the paper tray into the product.
Jun 16, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Size Error: The specified custom paper size is not supported in the selected tray. I have a Hp Officejet pro L7780 All in one. I checked the default printer and paper handling and it all says letter...
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper jam up in top of printer Tray one wadded badly -
Try using the cardboard backing of a large writing tablet by sticking it down into the tray where the paper goes. If there is a small piece of paper there, it will be pushed out.
Marie
Jan 26, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Unable to get faxes to print to legal size
here are the steps that i want you to follow inorder to use the tray for legal size.
1. On your printer itself, Press the SETUP BUTTON.
2. Scroll Down, and look for the option "Preferences", then press okay.
3. Scroll down again, then look for Tray Lock, and press okay.
4. Under Tray Lock, you will have an options there;
- Tray 1
- Tray 2.
5. If you are using the legal size paper for tray 2, then choose Tray 2 and press okay button to apply. And if you are using the Tray 1 for the legal size, you can go ahead and choose Tray 1 and press okay to apply. And this should work.
If in case you still have issues setting it up, please inform me.
thank you so much.
adonscott
Jul 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Printing from different trays
this can normaly be solved by going into the printer preferences and then setting the trays manualy in the software. otherwise the printer will automaticaly select the main tray first then move onto the mp tray. sorry if it sounds a bit vague but these options change from printer to printer and have not seen a k850 for a while Hope thyis helps Cops Pete@wedotoners.com
Aug 16, 2007 | HP Officejet Pro K850 InkJet Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
272 people viewed this question
Seeker5211
Seeker5211
