Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
No rinse My KitchenAid KUDS25SH washes, but there no water for rinse cycle iT is Whirpool, and will wash bt will not rinse. Problem just started after someone that did not know how operated it. What can I do.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Put it on the rinse cycle and shut off , cycle. Reset the breaker . Vitally
Posted on May 13, 2009
Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Whirlpool Dishwashers
Washer not taking in water in wash and rinse cycles in cold cycle
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | KitchenAid KAWS850L Top Load Washer
My KitchenAid dishwasher (KUDS25SH) start and stop
MY KUDI25 CHWH1 has the exact same problem...I'd love to hear about a fix!
Oct 22, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Cold water knob is not working
Check the screen on the cold valve. If power is getting to the valve and the screens are clean then the coil is bad. Check continuity if you have a meter.
eric
Jul 01, 2009 | Washing Machines
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool dishwasher does not go into wash cycle
you will need to replace the control bd. if it is not washing. I think that it is probably just filling and not starting the washing process and this would be a bad sump/mtr. assy.
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
